Results 1 to 26 of 26
    Established Member Two Rings BB'sAudi's Avatar
    May 26 2016
    Brentwood, TN
    Most cost efficient way to drop my car?
    So I want to drop my car an inch or so but don't really need a full performance suspension set up. What is the best/cheapest way to go about this? I know best and cheapest don't typically go hand in hand but any help would be greatly appreciated.
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    cut the springs
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Quote Originally Posted by IbisB8.5S4 View Post
    cut the springs
    Lol, Club Civic member? Best bet is to buy Eibach Pro Kit or H&R OE Sport springs ~$250....haha cut springs, love it.
    Veteran Member Three Rings S4_SH1640's Avatar
    Mar 15 2012
    Fairfield County, CT
    trust me, i did it all. its not worth it,you end up doing the job 2-3 times, and at the end... it spent more money in the long run. just save the money and buy mid range coilovers. i heard the ST coilovers are decent.
    Garage:
    B5 S4 Santorin Blue Stage 2
    B8 A4 Premium Plus
    D4 S8 4.0T
    Mar 28 2016
    Cambridge, ON
    I went with the Eibach Pro Kit shortly after purchasing my B8 A4 2 months ago. Overall very happy with the result, makes a big difference. However, definitely a little regret not just getting coilovers. Will likely go with coilovers sometime down the road...happy with the springs for now though.
    May 26 2016
    Brentwood, TN
    Quote Originally Posted by milito View Post
    What's the price difference between the pro kit and the could era you're thinking about?
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Agreed, just spring for coil overs. No pun intended. I would look at the Bilstein PSS10s. Limited Lifetime warranty, adjustable for ride and height settings. Your driving an Audi. Why would you want to compromise?
    Mar 28 2016
    Cambridge, ON
    Quote Originally Posted by BB'sAudi View Post
    I think the Pro Kit is about $270, although its about an hour each corner to install if you are not able to do it yourself, which was my situation. So I spent more on labour then for the springs. Have not looked into pricing on Coils at all yet, it will be a while before I consider doing that. All in all, Pro Kit was a solid, cost effective choice for me at the time. Which is why I decided to go with springs to begin with.
    Mar 28 2016
    Cambridge, ON
    Quote Originally Posted by B G 8er View Post
    Even though my decision was to go with the Pro Kit...can't argue with this.
    May 26 2016
    Brentwood, TN
    It's not that I want to compromise it's that I don't really need improved handling. Just want the lessen the wheel gap. But I will look into coil overs also.
    Established Member Two Rings DangerBruno's Avatar
    Apr 15 2014
    01’ allroad
    Scranton, PA
    For 550 you can get solowerks coils and for the money they are worth it. Not a racecar stiff suspension but adjustable and lower. I was going to get those and then got the deal of a lifetime on airlift kit so I dove into air.good luck.
    Sep 09 2015
    Mount Vernon, WA
    Quote Originally Posted by o1turbo30v View Post
    I'm kidding hahaha he said most cost effective... although in the long run it may prove to be the least cost effective
    Senior Member Two Rings KompressorLOgic's Avatar
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    well I am a cheapass, I ended up purchasing used solo werks from a fellow az member. they are a good combo of not too stiff, and good adjustability. my stock shocks had 100K and were worn out anyway, adding springs to old shocks will just wear them even worse....
    id vote get some solowerks and install them your self. that way u can adjust to what ever u need vs a static setting of a lowering spring.
    17 Audi A4 P+ ,Daytona Grey, Sport+,6sp manual,034 dynamic+ springs and sway bar,
    10' Audi A4 2.0T P+ Meteor Grey APR stg2, HFC, TDI IC, solo-werks S1
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Remember when the forums used to say "buy nice or buy twice?" .... What idiots. Cheap shit is where it's at.
    2016 S3
    Instagram- @Thisisastickup
    Active Member One Ring mwalt's Avatar
    Jan 20 2016
    Walton
    I can echo the responses on the Solowerks. Have 10k on mine, and don't have a single complaint. Ride quality is just a bit stiffer than stock, lots of room to adjust drop. Only complaint I have is that my entire rear threaded body spins a lot when trying to adjust it, so you have to find a creative way to hold the body while adjusting. That's the problem with not having any rubber between the rear shock mount and body. I may fix that in the future. All in all, great coilover for the money.
    May 31 2004
    What about shocks and springs from the sport package? May not be as low as some of the options mentioned but will maintain your ride quality.
    2011 2.0T P+ Sport 6MT, Integrated Engineering Stage II, STaSIS Exhaust, Spulen HFC, Roc-Euro SS, TDI FMIC, aFe Pro Dry Air Filter, E-Codes, 034 Transmission Mount, 19" AluFelgen SF-71, RS Grille, SunTek Carbon CXP 45, Shadowline Trim
    May 26 2016
    Brentwood, TN
    Quote Originally Posted by EuropaVin View Post
    That option was just presented to me. I'm definitely considering it. Because while I want the look of the drop, ride quality is number one. I mean it's an Audi!
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    cut the springs
    much easier to heat them up :P
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    I have solowerks coils and the ride is great.
    My 2009 A4 Prem+ Build thread
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Mar 11 2012
    Audi A5
    Ventura, CA
    There's a set of solowerks in the classifieds for 300 I think. Jump on those.
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Oct 17 2014
    NorCal
    take off your wheels.
    2019 RS3
    2014 S4 P+
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    My ST coilovers may be up in the classified soon too.
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    Drive your car off a cliff. Or buy lowering springs and drive it for a while. The ride will make you want to drive your car off a cliff. Find a time machine, go back in time....... Either buy a decent set of coils, or a good cup kit.
    Pedal Responce first responder.
    Jul 04 2012
    Woodbridge, VA
    Date fat women with fat children
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by vavJETTAw36 View Post
    /thread
    2016 S3
