Results 1 to 16 of 16
    Established Member Two Rings J4EZ's Avatar
    May 10 2016
    Colorado
    bought 2009 A4 less than 60 days ago
    The turbocharger needs to be replaced. The error code stored in the engine has been cleared twice. looking at almost 4k in repairs. I am livid to say the least, and feel like I was sold a lemon... Please any suggestions!? :(
    2009 Audi A4 Premium Quattro 2.0
    Feb 24 2013
    CA
    Where did you purchase it from?
    1. If it wasnt from a dealer with warranty, youre screwed and need to buy a used or new one. Most go with a k04 or similar.
    2. If you bought it from a dealer with warranty then youre gravy. Go get it replaced.
    Also, theres no way in hell that its 4k for a bad turbo replacement.
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    Just going to come out and say what everyone else in the forum is thinking - should have done your homework. Sorry to hear the bad news so early in. Was that a dealer quote or Indy shop? How many miles? Audi extended the warranty on our cars for the turbocharger and engine to 70K and 80K respectively. Waste gate has been known to fail and depending on which CAEB engine you have you may burn oil as well. TONS of info in this forum. You weren't sold a lemon, just one of the unlucky few.
    But if it's time for a new turbo I would go K04 and call it a day. Otherwise source out a K03 and have an Indy shop do the work - will be less than $4k.
    Good luck!
    Veteran Member Four Rings boomtime's Avatar
    Apr 22 2013
    Audi, BMW, Ford
    Rocky Mountains
    $4,000 seems high to me....
    that must be a dealer estimate. should be 1/3 that price anywhere else.
    The eventual supremacy of reason.
    CPMB K04+e85
    Twin Turbo 391
    E36 Drift Queen
    Oct 10 2012
    Zionsville and Saint John IN
    1400 for oem turbo and hardware and maybe what 700 labor? 4000 is an engine swap
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    OP, there's no need to spend even half of that amount. You can get a used OEM turbo for less than $500. A brand new OEM unit is only ~ $1,000
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    It will cost you <$650 to swap that yourself with a used OEM unit. It sucks, but it happens. You can check the turbo tsb if you got a P0299. There's a diy for the turbo swap as well.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    May 10 2016
    Colorado
    Thanks guys, so much more supportive than reddit lol.
    2 follow up questions:
    First, the engine was rebuilt around this time last year, audi should have a warranty on that considering they were the ones that rebuilt it?
    second, I brought it to the dealer a week after purchase when the check engine light came on, they said that there was an error code, but they cleared it..
    "TURBO CHARGER ERROR CODE STORED IN ENGINE CONTROL MODULE. HAS BEEN CLEARED TWICE"
    so wouldnt that be catching the dealer clearing the code?
    Oct 23 2014
    Buffalo, NY
    Quote Originally Posted by J4EZ View Post
    Your codes will come back even after being cleared, if the issue hasn't been addressed; so if the issue remains, I would expect (and hope) that the code comes back. Do you know what the code is? If not, I would strongly suggest purchasing Carista and the appropriate OBDII dongle for your phone; wifi for iPhone, or bluetooth for droid. Otherwise, you can get a VAGCOM or borrow someone's close to you. Without that code we're shooting in the dark here, but this is a pretty common problem with our cars. Do you hear a metal on metal ticking noise when coasting? That's a pretty tell tale sign of a wastegate failure. Also, how many miles are on your car? The VIN specific TSB may still apply to your car.
    If the work was done at an Audi dealership, the parts generally are covered under a 1 year or 12,000 mile warranty IIRC, but I am not certain if that is transferable after a sale. That being said, I would venture a guess that the "rebuild" was stage II of the oil consumption issue. If so, they generally are replacing pistons & rings, but occasionally replace the short block, sometimes the long block, and sometimes the turbo, so its possible that they left your turbo alone. I had stage II done around this time last year, but ended up swapping my turbo myself due to a P0299. Obviously, check with your local dealer first; provided you aren't tuned. Also, check out the two threads below.
    http://www.audizine.com/forum/showth...umption-Thread
    http://www.audizine.com/forum/showth...lapper-(P0299)
    This will help you change the turbo, if you undertake it yourself.
    http://www.audizine.com/forum/showth...4-Installation
    °2011 A4 | 6MT
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    I'll fly out to colorado and replace it all parts and labor for $2,800 lol
    2016 S3
    Instagram- @Thisisastickup
    Veteran Member Four Rings Lambda13's Avatar
    Jul 07 2012
    A4, car parts, paint, random sockets, OEM parts.
    Boston, MA
    Quote Originally Posted by b6Hate4 View Post
    Do you need me to stand there and look like I'm helping again?
    My 2009 A4 Prem+ Build thread
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by Lambda13 View Post
    +rack of coors light.
    2016 S3
    Jul 07 2012
    Boston, MA
    Deal.
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    lol this is me haha
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    May 10 2016
    Colorado
    UPDATE Went back and talked to the dealer I purchased from, and 4 hours later we came to the resolution that he will be replacing the turbo at no cost to me :D
    Jul 07 2012
    Boston, MA
    Best outcome possible. Glad to hear it worked out.
    Sent from my SM-G900V using Tapatalk
