I finally upgraded to a real version of VCDS and can get decent logs now. I decided to do 5 pulls in 3rd gear using APR's method they request when troubleshooting. I'm trying to figure out why my car still pings like crazy when it starts to get warmer out. I'm running an early rendition of a tune from Gonzo at CTS (from back in 2013). I think it's time for a new tune. Mods are listed in my sig.
Log 1 - Boost and Fueling Diag
Log 2 - Boost and Timing Diag
Log 3 - MAF/Load Diag
Log 4 - Misfire Diag
Log 5 - Boost and Timing
The logs were done in order on a flat stretch at 1279ft MSL. Weather conditions were 1010 mbar and 88°F/31°C.
I'm about as far from an expert as you can get when it comes to interpreting these things but this is what I think I see...
- I'm running rich in the high RPMs
- Timing is retarded aggressively on log 2 and less aggressively on log 3. Does the ECM make adjustments like this every time the car is power cycled? I see this trend each time I start the car.
- I should probably get some logs with IATs (however, they usually stick within 10-15 degrees of ambient once the FMIC becomes effective)
