Results 1 to 10 of 10
    Registered User Two Rings Oakes Detail's Avatar
    Aug 11 2009
    Audi A7 Prestige, BMW M3 ZCP, Audi R8, Audi Q5
    West Chester, PA
    Lamborghini Murcielago Roadster - Made Better than Factory - Oakes Detail
    2006 Lamborghini Murcielago Roadster in Blue Hera sporting just nine thousand needed a total make over. New to the owner, my goal was to get it looking better than when it left the factory. Which gave me a roman scrolls worth of work. Starting with removing the existing partial clear bra which looked tired and faded but did it's job preserving the front end.
    This project also included full undercarriage detail, requiring the removal of the wheels, followed up with paint correction and CQuartz Finest ceramic coating. I also installed new Xpel clear film and replacement of the existing battery tender wiring.
    The following photo journey will show you all the start, evolution and finish. The pictures speak for themselves. Starting off with some shots of the existing partial clear bra showing its faded textured and dated templates with far more reliefs than necessary.
    After removing the film, we could see that the front end was preserved in regards to rock chips, however the pre-film detail certainly left it’s mark….
    Heavy marring and holograms were rather persistent through the whole vehicle, though most noticeable in the front end. With the film removed and the vehicle prepped, we moved ahead with the multi step correction. Lamborghini paint is a bit notorious for being stubborn but that caused no waiver here. A glimpse at some 50/50 photos and some more before and afters of the paint condition.
    The front end was just the start of bringing the Blue Hera paint back to life, which was being served no justice in the state it was brought to me. The following photos show the front end in the process of being clear wrapped, the vehicle was completely corrected and detailed before the film was applied. Wanted to keep the results together to give more light to the final results from start to finish.
    Photos showing the seamless edges and full wrap overs
    Another before and after photo of the paint correction performed on the B-Pillar/Air Inlet section
    A little out of order but here are the results of the undercarriage and wheel detail work, while on the lift all of four corners were completely degreased and treated. The rear underbody was polished and coated as well
    The wheels cleaned, clayed, polished, re-prepped and then airbrushed with Cquartz DLUX ceramic coating
    Aug 11 2009
    West Chester, PA
    Now for the final shots of this rolling piece of art, showing the flawless film install and the pop from the correction and CQuartz Finest installation!
    As always, thanks for checking it out and hopefully you enjoyed the write up as much as I have enjoyed working on this icon!
    Oakes
    Veteran Member Four Rings A5MD's Avatar
    May 22 2009
    2009 Acura MDX Tech, 2015 X5, 2014 Police Interceptor, 2018 Civic Sport Hatchback
    MD
    Man that is some superb work. Would that be a whole day job? Just the time and detail that you professional put in are ridiculous. Anything more than an hour for me and I'm done lol
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    That's a lot of work, huh?
    Fantastic job. It looks great!
    2007 Avus Silver Rs4
    Bone Stock
    Veteran Member Four Rings Brooklyn's Avatar
    May 08 2004
    NoVA
    I'd guess closer to 3 days, if not more A5MD. Phenomenal results!
    l 2013 S6 l Oolong Gray/Black l APR STG 2 l MILLTEK NON-RES l APR Downpipes l
    l 2022 Tesla Model S Plaid l Midnight Silver Metallic/Black l XPEL Stealth Wrap l
    l Hers: 2019 e-Tron Prestige l Manhattan Gray/Black l XPEL Stealth Wrap l Vossen HF-3 Gloss Black l
    Aug 11 2009
    West Chester, PA
    We spent the better part of a full week straight on this beast, not that it needed that much work, but because we really like to make sure we go over any and everything.
    Established Member Two Rings X Y Z's Avatar
    Mar 20 2013
    SM610, AE86, FJ60
    Portland, Oregon
    Fantastic work as always! Were you touching up the wheels with the air brush or applying a coating?
    Aug 11 2009
    West Chester, PA
    Quote Originally Posted by X Y Z View Post
    Applying a coating, the wheels were in phenomenal shape aside from some scarring on the inner barrels.
    Established Member Two Rings circle's Avatar
    Feb 16 2016
    Valhalla
    awesome work!
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    and the price for the paint correction/clear wrap is. . .
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
