Page 1 of 4 123 ... LastLast
Results 1 to 40 of 152
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    MMI 3G+ Conversion from MMI 3G(2010-2012) DIY with Component Protection removed.
    Well there are a ton of threads out there, but you need to really read all of them to actually know what you need to buy to do the conversion. I finally had time to get mine installed this weekend so I am putting all the info here in one post that i used to do the conversion.
    I have a 2010 S4 with 3G B&O, the MMI 3G goes to the 2012MY.
    I purchased the Head unit and Control Panel off Ebay. Cost me around $600 for the parts to do the conversion.
    Really like the newer interface, also brings Video over through MMI, Bluetooth Audio without an adapter, and Google Maps.
    What you need:
    Head Unit 8R1 035 746C (A and B also work, C is just newer, i believe it goes to F now also)
    MMI-Controls: 8T0 919 611 C WFX or 8T0 919 611 L WFX (with Start/Stop button) or 8T0 919 611 B WFX (without Start/Stop button)
    In other posts a Module 4G0 035 082(HD radio) is what is prefered. My car is a MY10 it had a Radio module 4F0 035 082A(non HD radio), it worked half the time, the volume would mute out and when you try and adjust the volume it would be "Currently Unavailable". Note: you need to have component protection removed for this module also.
    There has been mention that if you have the Radio Module 4G0 035 082"G", it will not function correctly for Sirius.
    I purchased a 4G0 035 082 without a suffix as that was reported to work well. Had a ton of speaker codes pop up with this unit and audio wouldn't work. Found that the coding had a subwoofer amp turned on (you can also see the subwoofer option in the audio settings). to fix this, change the coding to 0200070(1)0000000001. There was a (2) before. This will fix the speaker errors and play out audio to the amp.
    You can Check with a Vagcom Addreess 56-Radio to verify what you have.
    GSM Antenna cable. I ordered mine from: (people also just use a generic GSM antenna off ebay with the Fakra connector and mount it by the window instead of using the OEM antenna that is already in the car.)
    rfsupplier.com > Custom RF Cable Assembly Wizard:
    1 x Coax Type: RG174; Length: 500cm; Connector A: Fakra D Right Angle Jack; Connector B: Fakra D Straight Jack (F03DSJ-F03DRJ-174-500)
    Removing the Head Unit, MMI controls, running the Antenna wire are well documented from Richib86
    http://www.audizine.com/forum/showth...=1#post8091112
    Some Tips and hints that you may run into:
    Enable The hidden Menu Via Vagcom
    [5F - Information Electr.]
    [Adaptation - 10] -> Channel 6 -> Change 0 to 1
    To get into the hidden Menu hold the Car and Menu buttons down for 5 seconds.
    My unit came out of an A4 so the Splash screen said A4 when powered up.
    To change this in the hidden menu:
    car/carcodingvehicle
    Select No of Screen:
    15 --> A4
    16 --> A4 Allroad
    17 --> S4
    18 --> RS4
    The car it came out of also didnt have ADS.
    To add the ADS menu, just do the portions of this Guide that are in the hidden menu.
    http://audienthusiasts.com/VagCom_FL_ADS.html
    While you are in the hidden Menu, its a good time to activate the following if you want:
    Enable Battery meter
    [Hidden menu] [car] [cardevextdevicelist] [Battery] Enable
    [Hidden menu] [car] [carmenuoperation] [Battery] Set to 5
    I had 2 Faults after the install, they dont affect the unit, but if you want to get rid of them:
    03276 - Please Check Software Version Management
    http://www.audienthusiasts.com/Appli..._SVMError.html
    03157 - Functionality limited due to Communications Disruption
    Is due to having an option in the MMI car selection screen that the car does not support, ie: interior lighting. You need to go into the hidden menu and clear out the ones not compatible.
    You may get error 03175 and this post shows how to get rid of it
    http://www.audizine.com/forum/showth...1#post10353818
    You will get Component Protection when swapping the Head unit. To date the only way to get rid of it is to go to the dealer. I was able to figure out how to use a VCP cable to read and write the eeprom from the old to the new. It is partially outlined here: http://audienthusiasts.com/Infotainment_EEPROM.html
    I may offer to help do this service but you will need to send me both units. This would save you from the dealer.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    Great info here! This is on my long list of eventual to-dos as well.
    Side note: great placement on your V1 box!
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Aug 25 2008
    Boston, MA
    Good stuff OP!
    The only thing I couldnt get to work was the steering response change when you changed the setting ADS setting (i.e. comfort to dynamic). It seems to always be in comfort. Hopefully your links in your OP will help solve this!!
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by dzasta View Post
    Good stuff OP!
    I know if you try and change it Via the MMI it will not take, you have to do it from the button still. You can do the individual settings. From researching it, it is a limitation of the ADS module since the b8 doesn't have the latest ones, one could retrofit it, but i think its more hassle than its worth.
    Oct 03 2015
    Suisun City, CA
    I did the same conversion right after purchasing my B8. However, I haven't been able to clear the 03157 fault at all. I'm sure it's something super simple that I'm looking over, but I haven't been able to find which setting doesn't correspond to my car...
    Mar 21 2015
    Nice little write up and conversion.
    Aug 25 2008
    Boston, MA
    Quote Originally Posted by infinkc View Post
    Were you able to get to Address Word 44 (Steering Assist) through the vag com? I get a "No Response from Controller" error msg. I wonder if this is why i dont get the different steering modes. I dont have the dynamic steering option but it still used to get stiffer when i changed the steering to dynamic.
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Nice work. Did you read and write eeprom as per David website or you manage this via OBD?
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Feb 13 2004
    S Ã C, CÃ*
    Tad confused, so you don't have ads, but you activated it on the mmi3g+. Steering is greyed out? How did you control the ads before the mmi retrofit?
    Quote Originally Posted by Gunnark100 View Post
    Yea done all over OBD, but used the website for the locations of the eeprom to modify :)
    Oct 21 2012
    Earth...
    Respect
    Aug 25 2008
    Boston, MA
    [QUOTE=infinkc;11659853]Tad confused, so you don't have ads, but you activated it on the mmi3g+. Steering is greyed out? How did you control the ads before the mmi retrofit?
    My car is a prestige 2010 with sport diff. No adaptive cruise control with dynamic steering. So when i had the older 3G MMI i could change the steering to dynamic and it would get nice had heavy. After the 3G+ conversion, changing the steering to dynamic now does nothing. when i check dynamic steering via VAGCOM i throw a code for having no dynamic steering. I'm hoping i have some setting wrong somewhere.
    Are you still able to change the steering to dynamic and feel the difference after the conversion to 3G+?
    Feb 13 2004
    S Ã C, CÃ*
    [QUOTE=dzasta;11660594]
    Sorry cant really help you much, mine works. I say look at the hidden menu and make sure that all the setting match the ADS guide in the first post.
    Another + to the mod, is the presets are the first screen to come up, on the 3g you always have to press the mmi button which always bugged me.
    Feb 13 2004
    S Ã C, CÃ*
    Added some more details to the first post, my speakers cut out pretty often, i swapped the radio unit out since mine was an older unit and there are many discussions that a newer unit is required. Some new coding was need. The radio unit also has component protection! I haven't removed it yet, but audio plays with Media fine(CD, BT, SD), you just dont get radio or sirius.
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Why was a GPS antenna cable needed?
    Oct 03 2015
    Suisun City, CA
    Quote Originally Posted by pierreb View Post
    That cable is actually for your connection to the cellular portion of the antenna.
    2020 A4 allroad
    NH
    Quote Originally Posted by JeromeS13 View Post
    So a 2010 US Spec car with 3G MMI would need this additional cable?
    edit: I understand now. The OEM connector is in the D pillar and I just need this cable to get from there to the new H/U. Correct?
    Oct 03 2015
    Suisun City, CA
    Yes. As Kris specified above, this is the exact walk through from where he converted his 2010 S4
    2020 A4 allroad
    NH
    Sorry yeah, I have an A4 Avant so I wasn't sure if I could just assume it would be there. I'm now googling to see if I can confirm this GSM connector location on my car.
    Feb 13 2004
    S Ã C, CÃ*
    Yea sorry, it's not gps, it's GSM.
    2020 A4 allroad
    NH
    For the record, in the avant the spare GSM connector is right underneath the shark fin antenna inside the car. I haven't received my cable yet so I don't know if 5m will be enough.
    2020 A4 allroad
    NH
    I finished mine today. The 5m cable was fine even if I destroyed my fingers routing it to the shark fin antenna connection. The MMI module I got already had the the proper phone upgrade to support AT&T bands so I just had to plug in my ipad's SIM with an adapter and everything worked. Off to the dealer for CP removal.
    2020 A4 allroad
    NH
    Success!
    Oct 23 2014
    Buffalo, NY
    What does the dealer charge, approximately, to remove component protection?
    °2011 A4 | 6MT
    2020 A4 allroad
    NH
    An hr of labor. Mine is $130 shop rate.
    Oct 23 2014
    Buffalo, NY
    Thank you! I found a headunit for a great price, so just trying to figure out the final cost. Maybe I'll just pick up the headunit now, and save this for something easy to do this winter.
    °2011 A4 | 6MT
    2020 A4 allroad
    NH
    If you choose to also replace the radio, you will need cp removed for both so do them at the dealer at the same time. You don't want to pay for 2 visits.
    Oct 23 2014
    Buffalo, NY
    Good point! I have a bad feeling that my local dealer will have no idea what I am talking about though. They aren't overly helpful, and new things seem to put them on the defense, but $100 for the head unit is a steal.
    °2011 A4 | 6MT
    May 31 2011
    moore
    @infinkc Thanks for the great write-up, is it possible to get the name of the vendor you purchased the head unit and MMI controls panel from? If it's against the forum's policy please send me a private message.
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by hiwasss View Post
    got it on ebay, LKQ, found their prices to be very reasonable since they are such a large company.
    Mar 04 2016
    Carolina
    I'm interested in how you did your radar detector, any info on that?
    thanks
    Feb 13 2004
    S Ã C, CÃ*
    Quote Originally Posted by kyducati View Post
    thanks
    I had a thread on it, but the images are not hosted anymore. its actually for sale now http://www.audizine.com/forum/showth...6#post11891216
    I modified the v1 display to be completely flat, changed the LEDs, cut the circuit board to fit, cutout the MMI bezel, ran an external cable to the board. Was a ton of work to do, but turned out great.
    May 31 2011
    moore
    @ infinkc - do you know whether the MMI unit model 8R1 035 746 E should also work?
    Oct 03 2015
    Suisun City, CA
    Same part number, just newer revision.
    2020 A4 allroad
    NH
    Try and get a "G" or later. You want to make sure you get one with the updated modem hardware in it so that it supports AT&T SIMs at 3G. otherwise you'll be stuck with T-Mobile 3G or AT&T at 2G.
    May 31 2011
    moore
    For model ending in G, would it support T-Mobile also along with AT&T?
    2020 A4 allroad
    NH
    Yes it should. The whole reason for the original gsm modem hardware update inside the mmi head unit was to support the refreshed t-mo 3G bands.
    May 31 2011
    moore
    I've gone over Richib86's pics many time and still have trouble making out where the Fakra GSM cable connects to the shark fin. Is it near the rear passenger side or rear driver's side? Anyone has a zoomed out picture would be greatly appreciated.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    I believe its the drivers side, but there's a connection on the pass side as well I forget what for. Anyways once you get the rear deck lid removed take off both the side panels and everything will be there.
    For a proper step by step of that process i suggest getting a subscription to alldatadiy, or finding a copy of the factory manual.
    2010 S4, DSG, too many random parts. 2004 Mazda RX-8, was highly modified then went back to stock.
    Feb 13 2004
    S Ã C, CÃ*
    It's the passenger side, you just pop off the pilar panel and it's in the corner close to the window. I had a pic, need to look for it.
