Page 1 of 4 123 ... LastLast
Results 1 to 40 of 135
    Senior Member Three Rings freuds's Avatar
    Sep 21 2008
    2002 911 Turbo X50, 2004 4runner
    Delaware, Ohio
    JHM RS6's VS. SRM RS6's
    I see a lot of people running SRM's and i'm wondering if they're a better option than JHM. What's everyones take on these two?
    Current: 2004 4runner SR5, 2002 911 Turbo X50
    Sold: 2000 Nogaro Blue S4 Stage 3, 90,000 miles; B6 A4 Eurospec 2.0T/GT3071R Turbo/Spec Stage 3 Clutch/AWE FMIC/AWE Catback Exhaust/ 3in dp/630 cc injectors/revo software.
    B5 Silver S4 Stage 1.
    May 22 2013
    2001 A4 Avant 1.8t GT2871r 630cc ev14
    Las Vegas, NV
    Both good options. But I haven't heard of too many people lately grabbing the jhmd. But I think they have good quality stuff and are devoted to our platform and more.
    Sent from my SM-G930T using Tapatalk
    Sep 21 2008
    Delaware, Ohio
    i'm torn because i'm definitely going to make the upgrade soon. I just don't really know a lot about SRM.
    Veteran Member Four Rings Corbett's Avatar
    Mar 09 2011
    Detroit, MI
    Both are from China. One company admits it. One does not.
    Sportec RS600 + 6 speed swap. Fastest RS6 in the USA
    Active Member Four Rings
    Sep 14 2009
    s.e. mass
    Quote Originally Posted by Corbett View Post
    Troof... There also is another exact same turbo sans branding thats been around since before either, also admits China openly & freely. :)
    IG: @PB5S4
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Aren't all the bolt in ready rs6 turbos chinese? I thought the bw's had to be refitted (cut and rewelded)...
    2002 Pearl/onyx S4 Avant
    Sep 21 2008
    Delaware, Ohio
    Yep the BW RS6 turbos have to be chopped I heard as well. In terms of reliability, does anyone know which brand is best?
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    In my opinion more important then where it is built/assembled is the QC. If BW RS6 is an option then I would go that route.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Veteran Member Three Rings S4gasm aka LOTR's Avatar
    Sep 30 2006
    01 S4 Santorin 6 Spd
    Missoula, MT
    Quote Originally Posted by Yuppie View Post
    You're going to deal with pretty significant lag on full framed RS6's on the 2.7. Hence the reason SRM did k24 cold side. That was part of my deciding factor.
    01 S4/ Stg 3+/K24/+stuff
    08 A6 Avant/ S-Line/ 3.2/ bone stock
    Build Thread - http://www.audizine.com/forum/showth...ld-91-craptane
    Sep 21 2008
    Delaware, Ohio
    How long have you been running the SRM K24's?
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    I have 1500 miles at 23psi on my SRM k24s and so far no complaints at all. The only thing I'm not a fan of is the SRM inlets not fitting over the valve covers very well but it's not that big of a deal.
    Mar 22 2013
    AK
    Quote Originally Posted by S4gasm aka LOTR View Post
    False, the SRM units have a larger compressor wheel than the real RS6 turbos so there is actually more lag
    K24 is the BW or in this case Chicom cold side aka compressor wheel not turbine, the SRM turbine is most likely clipped
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    I also disagree. I ran OEM RS6 turbos on my car for years and thought they were pretty kick ass. As far as seat of the pants feel, I don't recall much difference between the Srm units and factory rs6 turbos. I know they're different a little on paper but I've ridden in both and feel the difference is relatively negligible.
    Home of the slowest s4 of 2014
    I buy 2.7 engines. Either short/long blocks. Message me!
    Sep 30 2006
    Missoula, MT
    Quote Originally Posted by freuds View Post
    2300 miles at 26-27 psi, rock solid so far.
    Quote Originally Posted by Drehmoment View Post
    Interesting, could have sworn when i read about them a couple years ago that was quite the opposite. Anyways, yeah probably splitting hairs at this rate.
    Sep 21 2008
    Delaware, Ohio
    what about Frankenturbos? Are they better than PJ K04's?
    Senior Member Three Rings t28sentra's Avatar
    Nov 18 2007
    B8.5 Allroad ,B6 S4, B5 S4 (Imola - Sold), B6 A4 USP , B5 A4 Sold, Laser B5 S4, Jeep Wrangler (Sold)
    Toledo, OH
    Nearly 25k miles on mine (JHM RS6-R). Very happy with them.
    B8.5 Allroad (APR K04 E85), B6 S4 (JHM Goodies), B5 S4 Imola Avant (JHM RS6-R), Touareg V10 TDI, B6 A4 USP (REVO Stage 3) SOLD, B5 S4 (EPL Stage 3 on Meth) SOLD
    Mar 22 2013
    AK
    No
    Sep 21 2008
    Delaware, Ohio
    Quote Originally Posted by t28sentra View Post
    Solid!!!! That makes me feel better about buying Chinese turbos
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Depends on what you consider better. They do make more power. Mine have over 30k on them without issue. If you want oem reliability then I would say they probably aren't better, but I haven't had an issue.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    These are all dimension-ally different products, depending on how you wish to use them will drive you toward one over another. 'Better' has no meaning without a criteria to evaluate against.
    Aug 24 2014
    Newport Beach, CA
    No direct experience, but I haven't seen any real reliability issues with either. Which is a good indication since the JHM RS6-Rs have been out for a while now.
    2024 M3 Comp xDrive
    Sep 21 2008
    Delaware, Ohio
    Quote Originally Posted by christianb5s4 View Post
    Exactly. I'm leaning more towards JHM for that fact alone that they're seasoned and I haven't heard anything negative about running them.
    Mar 22 2013
    AK
    Tial 605.2 are hands down a superior choice IMO they come with beautiful inlets that actually fit and superb oil/boost etc lines.
    But they cant be bought for cheap like the Chicom stuff.....if Tials/JHM/SRm would all be the same price nobody in their right mind would pick the Chinese counter fit products.
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    I wouldn't be so sure about that I have recently seen a tial 605 failure and have seen a few 770 failures in the past. I agree they are a great turbo choice and have really well fitting inlets but I would not put them at better choice over the
    RS6-R or K24's. Especially the bang for your buck. Just my 2 cents
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    There's a reason everyone and their grandmother are running srm k24s. They are proven and cheap. Yeah it may be Chinese but from what I've seen its made of the rarest chinesium. If you want power and something reliable and don't mind the wait then srm k24s are the way to go, end of story.
    Sep 21 2008
    Delaware, Ohio
    Quote Originally Posted by mikeb17 View Post
    How far is SRM behind on orders??
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Of note also, there's still a valid 10% off coupon for the SRM turbos if you choose to go that route.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Four Rings RocksForsSale's Avatar
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    SRM all day. I have yet to install these things though! I will report back once I tear into this thing.
    Veteran Member Four Rings NYEuroTuner's Avatar
    Oct 24 2008
    "Silvaro" B5 S4, 2013 B8 S4, 2018 RS3
    Quote Originally Posted by RocksForsSale View Post
    I put about 70k miles on SRM K24s, beat the crap out of them too driving from sandiego to Lancaster every weekend. Even when I removed them very minimal shaft play. Sean's snails are good to go.
    -- George
    SEMPER FI
    Build Thread--------------->My VR6 Journey<-Click it, Click it good.
    IABEDINDUSTRIES
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    Quote Originally Posted by Corradovolksb View Post
    All turbos can and will fail including BW K04s so that is not necessarily a valid point. What boost/tune/ miles blah blah blah.
    FWIW, I'm on my second set of FTs. First set was shit out of the box (only to be found after install SMH), second set failed at 6k miles (SMH).
    When my third set fail I will put a video on YouTube of me gouging my eyes out...
    Sep 21 2008
    Delaware, Ohio
    Quote Originally Posted by Zba View Post
    When my third set fail so will put a video on YouTube of me gouging my eyes out...
    Damn!! Thats rough! Staying away from F21's then..
    May 22 2013
    Las Vegas, NV
    I can't believe someone "actually" hit 70k miles on SRMs but who knows.
    I have yet to race anyone with k24 but I have oem rs6s and when I was in an s4 with oem rs6s then to k24s, I think the only difference is was feeling was from the oem being on 91oct and the k24 being on e85. Jhm even say not much different between theirs and chopped oem rs6.
    Oh yeah. I'm at 25psi all day
    Feb 26 2009
    00' S4 Stage 3, 2012 S5, 06 E55, 2016 Monster 1200R
    East Bay, CA
    Is there a difference in turbo frame size between the RS6-R or SRM k24s and the Tial 605.2s? Which is the larger turbo?
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by GKTS4 View Post
    I believe the TiAL is larger. It uses the GT28-65HTA compressor and NS111 turbine, both of which are larger than the RS6 hybrids from the numbers I've found. Specs, to the best of my knowledge, for the turbine inducer on the NS111 is 53.9 mm vs 50 for the RS6.
    Mar 09 2011
    Detroit, MI
    Now it's just getting silly around here. Come on guys, a Tial 605.2 is on a completely different level than a chinesium rs6
    Nov 05 2009
    Denver
    Seriously folks.
    Nov 17 2009
    2001 Audi S4, 2003 Jeep Wrangler, 1988 Nissan 300ZX
    CO
    I recently installed JHM RS6-Rs in my allroad. 3000+ miles so far, no complaints. great response and power.
    2001 Allroad - stage III+
    2001 S4 - was stage II+, meow totalled, but on its way to stage IV & WB
    2003 Wrangler Rubicon
    1988 300ZX Turbo
    Mar 22 2013
    AK
    Correct, the Tials are in a completely different zipcode than the Chicom stuff. Once you have both in your hands the quality difference is obvious but prize rules when the average B5S4 is worth a couple of grand and attracts that kind of clientel.
    Aug 24 2014
    Newport Beach, CA
    True, but even with that in mind Tials are a pretty penny even compared to OEM PJK04s. Really depends more on your power goals in terms of which to choose from, Tials are a great option as are other reliable turbo options.
    2024 M3 Comp xDrive
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Why would you compare to PJK04's in the first place... makes no sense.
