Results 1 to 7 of 7
    Feb 29 2016
    Bellevue, Ia
    Fuel Injector Short to ground
    So i started to feel a hesitation on the car and got a code of fuel injector short to ground. Any ideas on what to look for???
    Nov 03 2011
    All Over!
    Quote Originally Posted by pchrist View Post
    Check your wiring.
    Unplug the connectors from the ECU and the relevant injector (you don't say which). Then check continuity between pin 2 on the affected injector and the corresponding pin in the ECU connector. You'll need to grab a wiring diagram for your engine.
    Possibly you have a broken wire.
    Note: you need to unplug all the injectors in the bank you're checking, the rigid conduit does not allow individual injector disconnection.
    1986 Type 85 Audi 90 quattro
    Feb 29 2016
    Bellevue, Ia
    It came up on every cylinder!!! Not one specific
    Nov 03 2011
    All Over!
    In that case, check the switched 12V+ feed, which is common to all the injectors.
    Feb 29 2016
    Bellevue, Ia
    What am I checking for? If the cruise is on and you go up a grade it like chugs for a second then clears and goes! It's very intermittent
    Nov 03 2011
    All Over!
    Probably best if you post the log here.
    Feb 29 2016
    Bellevue, Ia
    I will have my mechanic pull it and get it posted. I did get a check engine light from it!
