Results 1 to 9 of 9
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    Chasing oil leaks
    I'm planning on chasing down a multitude of little oil leaks on my AEB 1.8T 99.5. Basically this means doing all the gaskets, seals, hoses, etc that are in any way oil related provided I can get to them. With regards to the ones under the intake manifold, would it make my live a lot easier if I simply pull the intake? Any real gotchas I need to look out for if I do pull it? Thanks for any feedback.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    Ehem Check the oil sending unit, crank breather hose, and the gasket on the oil housing, they all leak around the same time. and its a lot. Also Just take out the washer fluid tank and move the antifreeze bottle, after that u have a basket ball sized area to work with
    Just delt with this same issue with my 99 1.8 AEB, turned out after the car runs for a bit the sending unit would spit oil very quickly run down the side of the cooler and made it look like the cooler was leaking, I replaced several different things because i couldnt "SEE" a leak
    one of those days... every day.
    Remember to change your blinker fluid it may go bad on you!
    Sep 13 2014
    somewhere
    Also if u take off the intake, U will probably have to do a TBA with VCDS
    Dec 03 2014
    United States
    Thanks. I'll have to see if that will give me the room I need. I plan on getting the PCV stuff done while I'm down there as well as the oil filter adapter seals and gaskets. I'll add the sender to that list.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    Quote Originally Posted by Radskull1 View Post
    I've taken my intake off multiple times TB as well and I've never did a TBA. Is this unusual, dose it matter that mine is a 97 AEB, or am I missing something?
    Sep 13 2014
    somewhere
    not super sure, But the TBA has a chance to malfunction when its unplugged from the ECU, Basically the Car forgets its a car.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I'm AWM and my IM has been off plenty of times without ever doing a TBA. you need to take the coolant crossover pipe off to get the IM off of the two studs that it uses. I did it without taking the pope off and cracked the plastic coolant flange on the back of the head. Up to you what you wanna do. Hope with helped.
    Jan 18 2016
    PA
    I'm about to do oil leaks as well my motor is coming out. Makes it so much easier but in your case I imagine you are not pulling the motor.
    Dec 03 2014
    United States
    Quote Originally Posted by MarcRogers View Post
    I'd prefer pulling the engine, but don't want the extended downtime. This is the kid's car and I really don't want them driving mine if I can help it.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
