    Senior Member Three Rings Cousinphil's Avatar
    Jan 29 2015
    1954 Ford Jubilee Tractor,1986 Ford Diesel Tractor, 2006 GMC One Ton Dump, 1986 Nissan Flatbed Truck
    East Blue Hill Maine
    RPMs: How low can you go?
    I took the Audi over to Mount Desert Island today, down along the quiet side of the island, through Pretty Marsh, West Tremont, and Bass Harbor. Bar Harbor is on the opposite side of the island which is the noisy side. The holiday traffic was heavy coming onto the island, many out-of-state cars heading for Acadia National Park. But on the quiet side there was hardly any traffic. I went through a little village called Seal Cove with about the prettiest stretch of road I’ve seen anywhere, with white churches, apple trees in bloom and the salt water inlets coming close to the road.
    The Audi was running perfectly, the Michelins acting like they were glued to the road. I let go of the steering wheel a couple of times and the car went straight as an arrow down the road, neither pulling to the left or the right. This is a dream car. It doesn’t seem to use any oil.
    Anyway, I’ve put about 10,000 miles on the car since I bought it, and I’m starting to get an inkling of just how low you can take the rpms and still have decent power. This 1.8T engine really doesn’t like to go below 2000 rpm. At 1500 rpm in third gear, if you tromp on it, you’re going to hurry up and wait. If you floor it at 2500 rpm in the same gear you’re going to be pinned back in your seat. So what I’m wondering is, if I get a custom tune for this car, is it going to pull any better at low rpms? Is the power going to kick in any earlier?
    2004 A4 Avant 1.8T 6 Speed 120,000 miles Summer
    2005 A4 Avant 3.0 Tiptronic 80,000 miles Spring and Fall
    2005 A4 Avant 1.8T Tiptronic 105,000 miles Winter Tires
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Welcome to turbo lag. Not much you can do to gain that down low power with a small 4 cylinder. Unfortunately that is just how it is. It gets worse with a bigger turbo.
    A tune will help slightly, but not much down below boost thresholds (2500-3000RPM).
    Nov 10 2015
    Sudbury, ON
    Cannot really add anything other than exhaust components, to help spool time. A tune will definetly help with how hards it pulls, I am stage 2 tune, at 21 psi peak, where stock is 10-12.
    But a nice 2.5" downpipe back exhaust, and catless downpipe/3" HFC will help spool time. Mine comes on around 2200-2300rpm. (6 speed).
    A good tune though makes the car feel way better. Runs smoother, better on the highway in 6th, feels way more efficient. And 40+ hp difference is majorly felt.
    Get yourself a 3" HFC (high flow cat) or 3" test pipe, and a Stage 1/1+/2 tune and you will enjoy car alot more.
    2004 Audi A4Q 1.8T Ultrasport 6MT
    Frankenturbo'd, Meth, front mount, custom tune, full exhaust, bunch of other crap
    2004 Audi A4 Quattro 1.8T Tip Sport Pkg SOLD
    18" S4 Avus wheels l Eibach Lowering springs l Magnaflow 16601 l 3" TP l Pioneer Double Din l USP Bumper/S4 Door blades/Spoiler l Black on Black
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    e85 and a lot of timing helps.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Aug 26 2005
    The stock boost is specified as ~11 psig from 1950 to peak torque RPM, a flat line on the graph. A 2.5" down pipe with a High flow cat will help the turbo spool up at low RPM to increase low speed torque. Skip the ECU tunes. That won't help lower RPM torque.
    Vorsprung durch Technik
