I ran up to Autozone to get some vacuum line, but after discovering the elbow has two different Interior Diameter sizes the one size vacuum line wont cut it. The side going into the manifold is slightly larger. I tried to get it over but it just slices the hose and its already tight getting it on there where its located. I am trying to locate it on the damn OEM diagram but i cant see to find it on there, i am not the best with the engine diagram to begin with
So if someone can help me out so i can either order this tonight or run up to audi tomorrow as their parts counter might have something like this in stock. Here is a picture of a manifold i grabbed off google and where its sliced on my car. It comes from the lower manifold and goes into what looks like a check valve? I appreciate the help fella's. Yay for more bloddy knuckles getting this in
Anyone know exactly what the vacuum line serves, i am guessing it has to do with something with the manifold flaps, since there are right in the front on either side of this inlet. That is a guess, other side seems to connect to a check valve and a T to another vacuum. From what i read vac hoses on the front of the vehicle usually are the ones that will throw a p2006/p2007 code for the flaps being stuck closed because of a vac leak.
