Results 1 to 11 of 11
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Question: Oil Around The Spark Plug
    Replaced spark plugs yesterday, see some oil on the spark plugs chamber on one cylinder (not inside cylinder), question: is it the valve cover gasket? The other 7 chambers is bone dry.
    Established Member Two Rings Raudi RS4's Avatar
    May 30 2016
    SLC, UT
    Where exactly did you find the oil? On the threads? On the tip?
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    if the sparkplug wasn't loose to the point of leaking, i'd blame the valve cover seal
    Senior Member Three Rings prfktgntlmn's Avatar
    Sep 24 2011
    2017%20gmc%20canyon%20sle%20
    Atlanta
    Which cylinder, #5?
    2007 Audi RS4 Phantom Black/Black Premium
    Feb 13 2004
    The oil is on the outside of the cylinder (not inside) where the coilpack go over the spark plug. The spark plug is tight. May be about 10 drops. Cylinder #4 (passenger side, back firewall)
    Veteran Member Three Rings IslandHydro's Avatar
    Nov 29 2008
    WA State
    valve cover gasket
    B6 S4 Cabriolet
    Milltek exhaust w/ SW tips, H9 fogs (DRL), denison Ipod adapter.
    Debadged except the rings, TWM Leopard shift knob.
    TD Pro Race 1.2 Wheels, Continental Extreme Contact DWS.
    May 30 2016
    SLC, UT
    Quote Originally Posted by IslandHydro View Post
    valve cover gasket
    Junior Member Two Rings Heldyballs's Avatar
    Mar 29 2015
    2007 RS4
    IL
    I agree with the consensus that it's a valve cover gasket, however I'll add that I don't think it's that big of a deal. I used to own a car where this was a common issue (Infiniti G35) and two of my six cylinders collected a small amount of oil around the spark plug. I'd say it was maybe a Tablespoon over 50,000 miles but I never noticed any loss in performance. The G35 community kind of freaked out about the problem, and a lot of owners replaced their valve covers (plastic valve covers with built-in gaskets) at the slightest sign of oil infiltration for $500+.
    Spark plug threads are tight enough to keep 1500ish psi of combustion gasses in, so they will definitely keep thick motor oil out. Prior to changing spark plugs, make sure you use a rag to sop up as much oil as you can before pulling the plug.
    That being said, if you can't deal with something being wrong with your car (which I totally understand), spend a few hundred on a valve cover gasket and be done with it.
    Mar 11 2008
    B7RS4 & e46Ms
    valve cover gasket
    Quote Originally Posted by Raudi RS4 View Post
    Quote Originally Posted by Heldyballs View Post
    Nothing good ever came from oil outside of the engine, keep your oil where it belongs...inside.
    FRRG AZ Ring
    Feb 13 2004
    The funny thing is the cover side has oil is bone dry around but the other side is a little wet. Placed order for a set of gasket, my car need some love anyway.
    Senior Member Three Rings Striddy's Avatar
    Jul 15 2011
    nothing but memories
    Are you sure it's oil and not fuel?
    Ghost
