Results 1 to 6 of 6
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    Need Help. Loud tapping and check engine light (Video included)
    I started my car. It rumbled and shook the shut off. tried to restart and it started on but shook and the check engine light came on the i heard the loud tapping that sounds like valve tapping. Already checked cam follower and hpfp and they are fine.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Oct 24 2015
    Perth, WA
    Check your HPFP cam follower, if thats ok, you need to check the cam timing chain and tensioner at the rear of the engine behind the vacuum pump.
    My respray thread
    Mar 24 2013
    Oakdale, CT
    Scan for codes since you have a CEL. If your CF/HPFP are fine, it's likely your cam chain tensioner.
    -Adam
    Feb 19 2008
    NYC/DE
    Unfortunately my ebay cable won't read the engine codes for my B7 so I am unable to scan for codes.
    TuRboK1ng
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    judging by the way it's idling, I don't think it's a valve... I don't know what it is, but it doesn't sound like a valve at all. i'll put my money on the rear cam chain tensioner.. also, being inside the garage only makes the sound worse than what it actually may be.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    1) Get your codes read by a real cable/VCDS.
    2) Probably cam chain tensioner.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
