Results 1 to 9 of 9
    Apr 11 2012
    2008 VW R32 Audi TT 225 mk1 audi B7 A4 1999 Jeep Xj B6 a4
    Corning NY
    air coming from Regulator Valve (pan cake valve) when shutting off car is it normal
    We just purchased a 2006 for my son. We started working on the issues this weekend. idle jumping when in park. Fixed that bad maf sensor. But noticed that when shutting down the car on the regulator valve air vents though small pin hole on the valve is this normal?
    thanks
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    Que?
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Apr 11 2012
    Corning NY
    Que? what the hell is that?
    found the answer. its venting because of to much pressure in the engine. Swapped it out with newest version and no issues. Jeez you would think the b7 forum would know this.
    Veteran Member Four Rings Der Konig's Avatar
    Jul 09 2009
    '06 a4 2.0T 6MTQ, S3 '01.5 s4 avant 6speed, '12 KO4 Audi Q5
    Cleveland OH Area
    Quote Originally Posted by rfelker View Post
    Sorry was sleeping and hadn't checked until this morning
    Sent from my SM-N900V using Audizine mobile app
    '04 Corvette Z06 track car
    '15 F350 Platinum 6.7
    '06 APR S2+ A4 2.0T 6 Speed DD - current
    '12 Q5 2.0T P+ Built engine/CTS K04/IE tune - current
    '05 Ford F250 XLT 4x4 BP'd 6.0 - current
    '01.5 APR S3 S4 Avant 6 Speed - sold '04 Goodwood S4 6 Speed - sold '91 Jetta GL 1.8 8v manual swap - sold '99 SVT Cobra 08whp/308wtq - sold '01 Mustang GT - sold '88 Mustang LX 5.0 - sold '95 Jeep Cherokee Country - sold
    Veteran Member Four Rings rongeur's Avatar
    Jun 04 2011
    Clayton, CA
    Classic failed PCV. Now you know what it sounds like so when it fails again.... Which it will.
    2008 A4 2.0T Quattro 6MT S-Line QGM
    Stage 3 JHM TD05H-R on a fully built motor
    Build Thread
    Feb 15 2016
    Cambridge,Ontario
    helps if you use the terms we all know too .. if you had said PCV ( which is a term used sine the 70s ) , we could have helped you out .. im not sure anybody knows what the hell a "regulator valve " is.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Apr 11 2012
    Corning NY
    wow I guess I kinda sounded like a ass. Sorry guys.
    Probably should of said PCV.
    Feb 15 2016
    Cambridge,Ontario
    oh PCV ? that's a common problem . torn diaphragm .. swap it out ... after market ones seem to be junk so try and swing an Audi part on that :)
    kidding
    1976 Yamaha XS 360
    Apr 11 2012
    Corning NY
    Yeah I deserved that. Did swap it out. Problem resolved and car running normal now.
