Results 1 to 12 of 12
    Aug 04 2015
    Kansas City
    Part numbers needed
    I'm having a tough time finding the following two part numbers. Can anyone help?
    - Rubber grommet thingy that goes under the engine cover and holds it in place. There should be three but one of mine is missing and now it rattles like a mofo.
    - The cap that screws into the bottom of the oil filter housing.
    Thanks.
    Feb 15 2016
    Cambridge,Ontario
    yeah my cap is missing too. I figured it would be just part of the oil filter hpusing though .
    rubber grommet think im not sure what you are taking about . The rubber washers that go over the screws ?
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 16 2008
    South Florida - Ft Lauderdale
    The oil filter housing cap is part of the filter housing and not sold as spare
    The grommet PN is: 07C103226A
    Phil
    Feb 15 2016
    Cambridge,Ontario
    Phil
    Phill is it a threaded cap or just pop in ? Maybe I could find something suitable if its threaded and I can id the thread size.
    1976 Yamaha XS 360
    Oct 16 2008
    Threaded cap
    Senior Member Three Rings Van Black's Avatar
    Sep 07 2015
    Romania
    If you know a kickass machine shop they can make one for you, otherwise I'd look in scrapyards
    -Alex-
    07 A4 2.0 TFSI Quattro,Rebuilt engine, BPG pistons, S-Line interior, S-Line suspension, S4 brakes, RNS-E & Bose
    Feb 15 2016
    Cambridge,Ontario
    yeah not too many engines to be found , everyone I have checked the whole engine has been scavenged .. gees I wonder why ? ;)
    I think id have better luck finding the thread size.
    1976 Yamaha XS 360
    Sep 07 2015
    Romania
    what happened to your filter housing?
    -Alex-
    Feb 15 2016
    Cambridge,Ontario
    on mine when I bough the car the cap for the bottom was gone. So that's all I need . I may eventually just get an aluminum one, but if I could find the cap for it in the meantime id be happy.
    1976 Yamaha XS 360
    Aug 04 2015
    Kansas City
    Quote Originally Posted by Van Black View Post
    Mine is missing the cap on the bottom. The housing is fine otherwise. Carfax showed that the previous owner would sometimes take it to Jiffy Lube, (*shudders*) so they probably tossed the cap in the trash bin.
    Sep 07 2015
    Romania
    That cap is there so dirt doesn't clog that valve, it won't loose oil if the cap is gone. There are plugs that I use when I work with hydraulic systems
    to plug leaking pipes;
    http://www.ebay.com/itm/Hydraulic-JI...UAAMXQ56ZSAXil
    Something like those ^ you can use one to plug the hole so it doesn't fill with dirt
    -Alex-
