Results 1 to 9 of 9
    Apr 09 2011
    Philippines
    Are the locks and keys on a facelift B5 same as the prefacelift B5?
    1997 Audi A4 1.8T Quattro - Stroked to 2.0L, ABA crankshaft, 83mm Wiseco stroker pistons, Comp Turbo CT3-5556, AEM FIC6, 630cc injectors, VR6 Throttle Body, Schrick cams, Supertech valvetrain, IE intake manifold, Treadstone TR11 front mount intercooler, custom 3" stainless steel exhaust, Turbosmart 48mm Progate, Apexi AVCR EBC, Ringer Racing Stage 4 240mm full face clutch kit, Devil's Own Methanol Injection w/ 14 GPH Nozzle, 30 psi of boost.
    Nov 03 2011
    All Over!
    The key blades may be similar, but the some of the locks are different.
    The door locks are different.
    The ignition locks are different.
    The glovebox locks are the same.
    The boot lock may be the same.
    This is based upon North American models, and comparing '98 to '00 models. '96 models will have completely different key fobs (infra red remote) and blade profiles, and of course all the locks will be different to those on facelift models.
    1986 Type 85 Audi 90 quattro
    Apr 09 2011
    Philippines
    Anyone tried to transfer the locks to a pre facelift model?
    Nov 03 2011
    All Over!
    Quote Originally Posted by mykeg6 View Post
    It would probably be so much more straightforward if you stated exactly what you're doing.
    What year is your car? What year is the donor car the locks are coming from? Which locks are you changing?
    Apr 09 2011
    Philippines
    I have another B5 which is a 98. My friend has a donor car which is facelift, not sure what year.
    I'm thinking of changing all the locks if possible. I don't have the key fob anymore, just the blade.
    Nov 03 2011
    All Over!
    ^^^ The locks are not interchangeable. Completely different door handles, and the locks don't change over. The ignition lock is different, they are different lengths, so a swap will mean replacing the entire housing / column.
    The glovebox and trunk locks will interchange, but that's just about it.
    Apr 09 2011
    Philippines
    Aw too bad. Thanks for the info though :)
    Established Member Two Rings maxpower2014's Avatar
    Mar 22 2014
    libya
    no its not the same and the boot not the same lock on the prefacelift B5 electric lock and the door handles are different
    Nov 03 2011
    All Over!
    Quote Originally Posted by maxpower2014 View Post
    The boot lock is the same on pre and post-facelift North American models. It's only European models that have different boot lock assemblies.
