Page 4 of 10 FirstFirst ... 23456 ... LastLast
Results 121 to 160 of 397
  1. #121
    Jan 10 2019
    ca
    I used febi chains on my project and the balance shaft chain was a little confusing but there are 15 links between all of the markers used on the B8, ignore the copper colored marker and the two right next to each other.
    Sent from my SM-G950U using Tapatalk
  2. #122
    Feb 06 2019
    Illinois
    This is great post, ordering parts today, I’m little scared
  3. #123
    Oct 24 2018
    Germany
    Quote Originally Posted by Snakeman View Post
    I was when I did mine, too, mostly due to fear of breaking the fragile parts. It proved mostly unfounded, though. I did all my work with a mirror. My suggestion is to go over and over the two-part video series from Edge Motors on youtube regarding the timing chain until everything in your head sticks. There's a thread I started that you can search for that has some pitfalls in it that I put out there, but it all worked out in the end.
  4. #124
    Oct 24 2018
    Germany
    Quote Originally Posted by LS1K5 View Post
    The balance shaft timing chain orientation also threw me off, then I decided to just follow the way Edge Motors oriented everything in their video since the place is solid and can mostly be trusted, I think. Car is back together and runs just fine, no additional harshness, nothing.
  5. #125
    Jan 10 2019
    ca
    So I got the car all back together again and it still has the p0016 code and the p2293 code, I'm guessing the intake cam timing actuator is stuck or something but the fuel pressure regulator two performance code doesn't make any sense. Mine is an A4 B8, has anyone run into this?
  6. #126
    Oct 24 2018
    Germany
    Did you check if your camshaft bridge screen was intact?
  7. #127
    Senior Member Two Rings NYDCB's Avatar
    Aug 22 2016
    Washington, DC
    Is it ever? lol!
  8. #128
    Oct 24 2018
    Germany
    Quote Originally Posted by NYDCB View Post
    Is it ever? lol!
    The screen in my factory bridge actually was intact, but I replaced the bridge anyhow. Some remove the screen, but that scares me seeing that the stupid check valve inside is also a failure point and breaks off.
  9. #129
    Jan 10 2019
    ca
    Quote Originally Posted by Kolbenringe View Post
    It was not intact but I found the other half in the exhaust cam oil passage and removed it, I also put new seals in the vacuum pump and there was some burnt oil in that screen but not too bad. Here is the timeline with this car: a couple months ago my friend stops by and asked me to check out the check engine light, read and cleared p0016 and the code came back within a few miles of driving. At that time the timing chain made horrible noise on start up but went away once oil pressure built up, he had been driving it for five thousand miles that way and other than the code it seemed to drive fine. A couple weeks ago he said the car made a loud noise on a long start up and had no power, I checked and cleared the codes again p0016 and p0299. I drove it up and down the driveway and the codes came back this time with the addition of p2293, I checked the cam tensioner and timing. It had jumped at least one tooth but still idled fine and the tensioner was at the limit of its travel but still working. I replaced the balance shaft chain, timing chain, tensioner, guides and now the car starts up normally, idles fine and has good power but the p0016 and p2293 codes persist.
  10. #130
    Jan 10 2019
    ca
    I used a dial indicator to verify TDC and this is where the cam timing is now, somebody has been in here before and I think they may have screwed up the timing chain drive gear so that it's no longer oriented to the crankshaft correctly.
  11. #131
    Jan 10 2019
    ca
    My suspicions were correct, if you have the p0016 code take the timing chain drive gear off and inspect it! Don't learn the hard way like I did and assume that it's installed correctly, I should have verified the timing mark on the crank pulley and TDC before taking it apart. I was wondering why the crank pulley was a little wobbly before I disassembled it, now I know.
  12. #132
    Jun 27 2011
    Oh jeeze. You’d think one would double check that the notch was lined up before cranking it down. Evidently not...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
  13. #133
    Feb 24 2004
    Minneapolis
    I see your note about the chewed up timing gear so you're right, someone really didn't know what they're doing. But you also can't tell much from the timing links lining up on the cam sprockets. They only line up about once every 20 RPMs.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
  14. #134
    Feb 15 2016
    Cambridge,Ontario
    Yup this is an install problem. Always verify everything on install. You put it back wrong.
    You don’t get to blame the last guy. Uou own this
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
  15. #135
    Jan 10 2019
    ca
    Yes, I said I own this! Read the post, I do get to blame the last guy for screwing up the timing gear. It shouldn't go on more than one way, wtf is wrong with a key way Audi?
  16. #136
    Jan 10 2019
    ca
    So car is done and drives great now, no more p0016, p2293 or p0299 yay!
  17. #137
    Feb 06 2019
    Illinois
    I didn’t order parts yet, i have a6 2014 2.0t 65k miles, only p0016 code at the moment, engine run smooth, everything seems fine, hoping for best,
  18. #138
    Feb 06 2019
    Illinois
    4 weeks ago i replace pcv, i had p2187 and whistle sound, bought new one from dealer (so I thought)and after replacing i get those IMG_0267.JPGIMG_0268.JPGIMG_0269.JPGIMG_0270.JPGIMG_0271.JPGIMG_0272.JPG
  19. #139
    Feb 06 2019
    Illinois
    I had very long talk with guy in parts department when i try to replace a part, took me 40 minutes to convince him that the part he sold me was bad, than after receiving new one I inspected old very closely and discovered pry tool marks on digraph part
  20. #140
    Feb 06 2019
    Illinois
    Looks like guys in audi exchange in chicago refurbish parts and sell them as new
  21. #141
    Feb 06 2019
    Illinois
    I informed AudiUsa about this, and they send me thank you card and free first aid kit( so I believe i will need this one after my next visit to this dealer)
  22. #142
    Feb 06 2019
    Illinois
    So long story short do You guys thing that very bad oil separator can contribute to p0016
  23. #143
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by mtroxel View Post
    lol let me tell you something, ive built dozens of engines in my lifetime, but this is my first time working on german cars specifically this indepth. I made the same mistake and I can tell you that this is litterally the first time I have ever encountered a crank sprocket that is not keyed directly to the crankshaft. Most people would never speculate that the sprocket was not keyed in such a way that it would not come out of time with the crank itself if you loosened up on the bolt. I was fortunate in that my car wouldnt start after I put it all back together, and was lucky enough to discover the issue. German's have some really intuitive designs for things, and there are other things that you ask yourself, why would you change the way this works, when it has worked a certain way well for 100 years.
  24. #144
    Oct 24 2018
    Germany
    Quote Originally Posted by Spawne32 View Post
    They threw sense out the door in trying to save as much material as possible and make the engines as short as possible. They weren't just thinking of the interface, they were thinking of how to remove mass from the front of the car, particularly in front of the axle. They did this without common sense to reign them back in and the result is the EA888, where doing pretty much anything requires breaking down other regions of the engine or just rebuilding it (ie: changing a water pump belt risks having to remove the front of the car and performing a timing set job) or if the upper oil pan starts leaking, then it's engine or transmission out. The list goes on and on. The risk is high, even for dealers who performed stage 1 oil consumption repairs. Mine had it and I can totally see where and how they could have placed the gear wrong, but luckily mine was all good. The front crank seal was crooked, though.
    Overall, this company is as bad a shitshow as it was in the 80s, just fumbling around and accumulating the bad engineering and combining these philosophies in every new product.
  25. #145
    Feb 15 2014
    2011 Audi A4 Quattro, 2003 Audi A4 Quattro, 2010 Cadillac STS
    Ankeny, Iowa
    Thanks for the write up and information.
    I'm in process of pulling the motor on my 2011 A4. Bought it cheap due to oil consumption. Planning to pull engine and change pistons, rods and rings. Timing chain needs replaced, but didn't want to put that money into it if there was a possibility of damaged cylinder walls.
  26. #146
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by cyclonebax View Post
    Read over my refresh thread. If you have any questions just reach out
    1976 Yamaha XS 360
  27. #147
    Feb 09 2009
    Detroit
    My screen is shot on the back of the cam bridge, dealer says they only sell whole bridge for $300. Can I get just the screen somewhere, or put it back together commando style? I already spent a mint on OE parts but this seems like im being taken for a ride, I have a pack of those screens for my pipe.....
  28. #148
    Jun 27 2011
    You can just remove the screen. You lose that bit of protection but I’d question how useful it is.
    Mine was blown out, luckily I was able to recover the piece whole. But it was pretty clean and clear. No signs of blockage. So as long as you’re good about oil change intervals and use good synthetic and a good filter you shouldn’t really have much to worry about I would think.
    -CP
    2017 Q7 3.0t
  29. #149
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by EP9395 View Post
    you can get screens on ebay i believe along with the check valve .. you can even get a chineesium cam bridge for cheap. I just ripped out the screen and moved on.
    1976 Yamaha XS 360
  30. #150
    Oct 24 2018
    Germany
    Don't bother with the screen, pop it out, and hopefully the check valve doesn't blow out. Last I checked, replacement screens were discontinued by Audi, but Ebay has Chinese reproduction ones and I definitely wouldn't trust them. You can also order a Valeo cam bridge, which is the original. They even ground off the Audi-VW logos quite poorly on mine.
    Audi also has a recommendation somewhere to remove the screen and reinstall the bridge. Don't know where the document is.
  31. #151
    Jun 27 2011
    Previous 2.0t (FSI ones) had a similar inlet screen on the timing chain housing on the back that did the same thing, it was a last ditch filter for the oil going to the timing adjuster, tensioner, HPFP, and vacuum pump. It’s a basket style one, similar to a fuel injector screen filter but same basic purpose.
    It could also get really funded up and blow out, in fact I bought a timing housing off eBay to scavenge parts from and resell and the screen was blown out. Couldn’t find a replacement screen anywhere of course so I just popped it out. And I’m rebuilding a 2.0t on the side to swap into my b7 since the engine is sickly, and I also popped the screen out as it seemed kinda occluded. I would hesitate to say they’re unnecessary, however given they’re not available separately, and the components they’re a part of are over $300 new, I said screw it and will run without one on my b7. I ended up replacing the whole cam bridge on my q5 though, mostly out of an abundance of caution. And I hadn’t seen posts about being able to just pop it out.
    -CP
    2017 Q7 3.0t
  32. #152
    Oct 24 2018
    Germany
    I don't have the reference bulletin from Audi anymore, but here is one that refers to the bulletin:
    http://www.engineprofessional.com/TB/TB091917-1.pdf
  33. #153
    Veteran Member Three Rings Chillaxin's Avatar
    Mar 28 2018
    Jacksonville FL
    Mine was the same. An Audi service shop manager told me that they remove the screen when they see them broken. Just remove it and move on.
  34. #154
    Feb 24 2004
    Minneapolis
    Mine was gone at 85,000 miles too. I assume it was gone when the dealer did Stage 2 oil consumption at 65,000 miles. I just put it back on, I now have 110,000 miles on it.
  35. #155
    Feb 09 2009
    Detroit
    Thanks for the input, I’m discarding the screen, having a fearful moment here setting the lower timing chain, my other two marks lines up on the left tensioner and the crank, but the right side tensioner seems to be 180 out, the car ran with no issues when I took it apart and I was very careful that that the driver side shaft didn’t move at all, here are some pics, can I rotate any of these other shafts to align it?
  36. #156
    Feb 09 2009
    Detroit
  37. #157
    Mar 28 2018
    Jacksonville FL
    EP9395, The balance shafts can be rotated without damaging anything. From the last picture, your right side (driver side) balance shaft sprocket is about 180 degrees from where it should be. There is a little dot on the front of the sprocket, half way into a tooth, that should line up with the black link in the chain. Marks on the other sprockets look good. The balance shaft chain has equal links between all the black marks. Just line one up to the crank mark, then align the passenger side sprocket, and finally the driver side. Then start putting in your top and right guides, with the bottom left tensioner guide for last, then install tensioner.
  38. #158
    Feb 09 2009
    Detroit
    Quote Originally Posted by Chillaxin View Post
    Ok, I set the tooth on the crank, then held everything still and rotated the just forget side balance shaft counter clockwise a few rotations and now I have the little dots on the inner sprocket sandwiched and the mark is at about 2 o clock and matches the the mark on the chain. I was just hesitant because nothing moved much when I took it apart I was just hoping to drape the new chain over and it would all line up.
  39. #159
    Feb 15 2016
    Cambridge,Ontario
    DIY: Motor work, Timing tensioner or anything with the motor and front end
    Nope his pics look corect. That last pic is how it is supposed to look.
    The dots line up kn the sprocket as he has it. That is not where the link goes. It goes further to the right exactly how he has it
    This is my engine. Once he has the three dots lined up on the idler. Then you put the link on the dot on the idler. He has it correct.
    1976 Yamaha XS 360
  40. #160
    Feb 09 2009
    Detroit
    edit
