Results 1 to 9 of 9
    Engine confusion
    I was looking at this part for my car and i stumbled over something. It said 2.0l turbo models only, but no Quattro. What does that mean? Doesn't the a4 and Quattro version have the same turbo engine?
    Sent from my SM-N910V using Tapatalk
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Different configuration in the A3, S3, TT, etc.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    I don't think your question is making sense to me, did you mean you read the following description and it didn't make sense to you?
    Did you read somewhere:
    "2.0L turbo engines only, but not quattro"
    If so, it's most probably a misprint meaning the part only fits a FWD vehicle such as exhaust parts, etc.
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Quote Originally Posted by Sanjman View Post
    Yes thats correct. So in my case i was looking at a test pipe and it said that. So is the fitment different from a fwd to the Quattro?
    Nov 07 2015
    2004 Jeep Wrangler Rubicon, 94 Z28
    Pennsylvania
    Long story short, yes it's different fitment
    Nov 16 2006
    Skokie, IL
    No its not. Test pipe is identical for all 2.0t FSI applications on the B7
    Nov 07 2015
    Pennsylvania
    My fault it's the downpipe that are different. But point being some parts are only for fwd, some for Quattro be sure to check the compatibility charts they have.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Guys, I think OP is trying to communicate with us....
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Nov 16 2006
    Skokie, IL
    Que?
