Results 1 to 16 of 16
    Senior Member Two Rings yossefay's Avatar
    Jan 11 2016
    Pittsburgh/Youngstown
    Brake Squeal Delete Mod
    I noticed that after a long day of trying to keep up with my friends' RS5 on backroads and some highway driving, my brakes were squealing tremendously. What is a cheap way of eliminating this? I know a little about BBK, Akebono pads, etc, but with the stock setup I'd like to know what works best.
    2018 B9 RS5 in Nardo Grey | 20' BBS CH-R's | Milltek Non-Resonated Catback | Carbon Imports CF Lip Spoiler | 35% Tint
    | 285's |
    Nardo RS5 IG
    Senior Member Two Rings justr0's Avatar
    Jul 24 2015
    2001 Mustang GT, 2007 VW Jetta, 2015 Honda CRV Touring
    Its the stock break compound, you can't do anything about it. They stop squealing once they heat up a bit, so do a couple of hard break when cold. Other than that, there is nothing you can do except move to warmer climates lol
    2014 Phantom Black CPO
    P+/DSG/Sport Diff/B&O/Black Optic/Carbon Inlays/Magma Red & Black Nappa/19" Rotors/Supercharged Badges/Conti DWS
    Mods:APR II+DL501/InjenSP CAI/AWE Touring 90 BD+Res.DP/CR-15/EC AK+Sway+EL+Mounts/Bilstein B8/H&R OE/ECS Flush Kit+SS Lines/Motul RBF600/RS4 Grille/SunTek Carbon 35%/PC 19" Rotors/PD Emblem (Red)/Carista/BV DR650GW/Passport Max2
    TBD:Akebono pads/Slotted Rotors or JHM 382mm Kit
    Established Member Two Rings TheLetterJay's Avatar
    Sep 26 2015
    ATL | NYC
    If you're just looking to eliminate brake squeal, I'd say replacing the front pads (and rears if you don't like to mix and match) first are your best option.
    From my Moto X Pure using Tapatalk
    2018
    034 Mounts, Inserts, Rear Sway, Front Strut Brace | ECS Intake, FMIC | ABT H.A.S. | Forgestar
    Gone
    2014 S-Tronic
    Eurocode Alu Kreuz | CR-15 | 034Motorsport Transmission Mount, Strut Mounts, Rear Subframe Inserts | Solo-Werks | ECS Luft-Technik Intake, Rear Diff Mount Inserts
    Senior Member Two Rings Sudz's Avatar
    Apr 19 2014
    Beer Fridge
    Houston, Texas
    I would make sure you still have some brake pad left. Street pads are quiet when cold and will fade when they get hot, track pads squeal when cold but control the fade under hard driving.
    2004 A4 Avant USP 6mt, Motoza Tuned
    2015 BMW M4, 6mt, Mineral White Metallic, BPMSport Tuned
    2016 Z06/Z07 Vette
    Mar 21 2015
    Akebone, no dust and no squeal. Love mine.
    Senior Member Two Rings S4ilicious's Avatar
    Feb 09 2015
    2001 A4 2.8 Quattro
    Bay Area, California
    X2 on Akebono's they Eliminate the Nasty break Squeal and You won't get your wheels dirty nearly as fast !
    2014 Brilliant Black | 034 Motorsports filter | 034 DSG Tune | Black Fine Nappa Leather | Prestige | 7 Speed S-Stronic | Apr tune | Roc Euro Intake | X pipe Exhaust | Akebono Brake Pads | Deval CF Rear Diffuser | ECS Spacer Flush kit 10F 12.5R |
    Jan 11 2016
    Quote Originally Posted by justr0 View Post
    The problem only occurs when the brakes are hot, and I had them squeal on me in 90 degree weather haha.
    Did you do the install yourself? On stock calipers/rotors?
    | 285's |
    Nardo RS5 IG
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    You could always try re-greasing them.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Mar 21 2015
    Quote Originally Posted by yossefay View Post
    yes and yes
    Veteran Member Four Rings BoostEasy's Avatar
    Aug 07 2013
    2014 S5, S-tronic
    NE
    You need to use high temp lube and lube the parts of the brake caliper that touch the pad, pad ears and the sliding parts of the caliper where it's obvious metal sliding on metal. Less lube = better.
    But at that point, you're disassembling the pads and calipers to the point you could put in new pads so IMO why stop there. Just toss in the Akebono's and enjoy dust/squeak free driving.
    2014 S5 S-tronic. Phantom Black, 19" AG M590s, Akebono Pads, OEM RS5 Grill, Alu-Kreuz, Black Alcantara, MMI, Quattro Sport Diff, B&O sound, side assist.
    2011 335xi (gone)
    2008 335xi (gone)
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    Quote Originally Posted by amz View Post
    LOL!
    Jan 11 2016
    So I put the grease on the rotors, just like you guys recommended. Looks like I'll be needing a new car...
    I think I'll just get the Akebono pads and call it a day.
    | 285's |
    Nardo RS5 IG
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Definitely get the Akebonos. Check out Amazon and you can get them much cheaper than anywhere else. I bought the fronts and rears separately a month and change ago and ended up spending like $135, total. Took a few hours to do the install, just taking my time, and since then I've had no squeal, better braking linearity, and absolutely no dust. I literally didn't wash my car for almost 3 weeks, and the wheels still looked spotless. With the stock pads I had to clean my wheels at least every 4-5 days, since they'd get dirty so quickly.
    Akebonos are the way to go:
    Fronts: https://www.amazon.com/gp/product/B009AA17TO - $82
    Rears: https://www.amazon.com/gp/product/B007FF3P9Q - $50
    Senior Member Two Rings sigaddict's Avatar
    Jun 21 2014
    Plano/TX
    I assume you are kidding about putting grease on the rotors.....
    2012 S4 - ECS RS4 Grille
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    I switched to Akebono ceramics and they haven't squeaked yet. Bought them from rockauto
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    I think AMZ in post #8 was referring to cleaning and re-greasing the caliper slide pins and the backing plates of the brake pads.
    If it's squealing after some aggressive driving, it sounds as though you could have gotten the pads hot enough to glaze the surface. When this happens the pad surface texture changes and it can cause excessive squealing. You can remove the pads and inspect them, see if the pad surface has a sheen to them. If the pads still have a decent amount of life left take some sandpaper and sand the pad surfaces and both sides of the rotor faces. The sanding should remove the glazed surfaces and restore the pads and rotors.
    Also, the squeal everyone is referring to happens during the colder months when using OEM pads. It's a squeal that occurs when lightly applying brake pedal pressure but goes away once the brakes become fairly warm. I don't think you are suffering from these symptoms.
    Good luck OP.
    2018 Carrara White Audi Q7 3.0T P+, Cold weather package, Vision package, Warm weather package, Driver Assistance package and towing package
    Stock
    2016 Mythos Black Audi S3 P+, Black Optics Package, Tech Package, LED Lighting Package, B&O, Red Calipers
    Modded
    2001.5 Brilliant Black Audi S4 Sedan 6MT
    Stage 3
