Results 1 to 3 of 3
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Bad J-plug Replaced
    Finally got around to fixing my coolant leak which I suspected was from the dang plastic j-plug I didn't replace when I did my t-stat about 25k miles ago.
    My assumption was right, thing broke in half when I removed it, half on the j and the part past I-ring stuck in the hole.
    Replaced with ECS billet one and all is good again.
    Lesson learned, always replace with new plastic or upgrade to metal one with new o-ring.
    Veteran Member Four Rings Pr1ce's Avatar
    Aug 11 2014
    13' prestige
    Kissimmee
    Agreed indeed.
    J plug should always be changed when tstat and others in that region as well.
    Good job
    Veteran Member Three Rings tHatOne guY's Avatar
    Aug 20 2012
    06' Yamaha R1...Raven
    Mesa, Az
    I thought about leaving mine alone when I had the engine out since it wasn't leaking but I am glad I went ahead and replaced it anyway as cheap insurance.
