My 2002 Allroad, 2.7t is leaking coolant forward of the drivers turbo. the area is very difficult to see. I cannot find nor see the sourse but have location narrowed down to the following.
aft of the black hose that is attached to the block and runs between lh engine mount and block. I lightly pressurized the coolant tank and get a steady drip, running down the block.
There is a prominant lug perpendicular to the block with about a 5/8 inch dia hole that the coolant is running on, so the leak is above that. I am trying to avoid pulling engine, but this area is imposossible to see at this point. I have so far removed the lh turbo air outlet tube, cv shield and still cannot see source as it is above the subframe.
