Results 1 to 6 of 6
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    How to wire backup camera in an Avant?
    Or more specifically:
    Has anyone successfully fished a composite video plug through the rubber tube betweeen the roof and the hatch (the one that hugs the hinge)?
    I need to fish one through the driver's side. After fixing my washer hose on the passenger side, I struggle to see how it could be possible, but sure others have done it, so any clickity click tips would be most welcome.
    I don't want to be cutting and splicing the video feed wire.
    Cheers.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Aug 26 2005
    You can get the video cable connector through the boot at the hatch lid hinge, by removing the boot from attachment at the body and hatch lid, then lubricating the inside of the boot with dish soap or similar, and pushing the cable connector through the boot. After the connector is pushed through the boot, reattach the ends of the boot to the body and hatch lid after running the cable connector into the hatch lid.
    Vorsprung durch Technik
    Aug 13 2015
    NS
    Brilliant! Thank you. The soap did the trick and it went quite smoothly (pun intended!).
    Aloe vera FTW!
    Apr 15 2014
    Ottawa/Gatineau Canada
    I have one in my Avant.
    I used a wireless camera and a small screen for the receiver (everything was like 40 bucks on Ebay.
    I put the screen up by the sunroof controls and got power for it there.
    I got power for the camera in the back by jumping of the windshield wiper. so when I turn on my rear wiper...my back up camera turns on and the signal it sends to the screen turns the screen on.
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Aug 13 2015
    NS
    I am hardwiring mine and I wil tap reverse lights for power and trigger signal. I will eventually get a new stereo with touchscreen and input for the rear camera.
    In somewhat related news, I found a purple small vylinder connector on the passenger side D pillar that does have anything plugged into it. It looks like an antenna connector and I'd like to figure out what it's for.
    Aug 26 2005
    Quote Originally Posted by eljay View Post
    Aloe vera FTW!
