Just installed brembo 6 piston17z calipers on my TT, and replaced the rear pads. (Car is left hand drive)
Pressure Bled all four corners 3 times
First sequence - rear right, rear left, front right, front left @ 15psi
Second sequence - same as above - furthest from MC to closest @ 15psi
Third sequence - front left, front right, rear left, rear right @ 20psi
I have bled between 120 and 200ml each caliper per cycle, no visible bubbles, but I still have a brake pedal that hits the floor with little to no brake power.
Any advice?
