Hi all,
Tomorrow i will be starting the tear-down of my beloved girl to replace what i believe is either my HG or the cylinder head. A little background on the car, I purchased it in Feb of 2014 completely stock, now... not so much
without the spacers!
. recently I've been experiencing extremely rough idle. After I started noticing the rough running and misfiring i brought it to my mechanic to have him take a look. He gives me a call and tells me that my TB is so loose it can be moved and i confirmed before having him do the TB, after he told me this i assumed maybe my tensioner had failed causing the symptoms as this seems to be a common failure point. After having a full TB service to make sure all timing components were operating as they should, i thought i would have been fine.. NOPE misfires started occurring again and it actually started running WORSE than before, white sweet smelling exhaust, misfires on all four. After a bit of troubleshooting i decided to check the oil as i read on the forums to check, low and behold oil and coolant were mixing. Being that i have already spent major bucks on replacing the head last year (4 cracks along some intake runners) this time around I decided it’s time i DIY it.
So far I think i have read all of the DIYs on AZ, AW very informative stuff, i also found Pelican Parts has some step by step procedures with pictures as well, i will link them below in case anybody needs them. I received the parts a few days ago and moved the car to a buddys house to start the project! Although i have read all the threads and such i would like to ask if there's anything i should be looking out for when performing the job to make it easier and less stressful. here's what i ordered so far, all from europaparts
Vlave Cover/Head Gasket Set on sale $70
10 OEM head bolts $18.95
Oil Change Kit $47.90
head bolt tool $20.00
cam chain tool $25
TB Kit - $69.04 Serp belts,coolant locktite cam&crank seals, crankshaft bolts x 4, TB sticker
Rear coolant flange kit $37
Shipping UPS Ground - $19.95
Total: $308.45
I ended up not ordering a new WP, tensioners,and TB since it was just replaced less than 100miles ago.
