    May 20 2010
    New to the 2.7T - Oil Leak
    Thanks in advance!
    I have an oil leak on my just acquired 03 allroad 2.7T 6MT. I've done some searching on oil leaks, but have yet to read anything definitive (sounds like it's hard to call leak definitive on this engine without pulling it).
    I haven't been able to get the car up on a lift or ramps, but on Level 4, I took a few pics. Oil only seems to drip from the car after I turn it off, which is actually how I found it in the first place. I've been other places idling with the car on and haven't seen a leak, but less than a minute after I park, it's drip drip drip for a little bit. Eventually it then stops. The oil I could see is on the pan and the (I think) A/C lines running behind the pan. Would this be cam seals, valve cover (I was told those were replaced shortly before I purchased), half moons, or oil pan seal?
    Also, what is that stud randomly sticking out between the two lines?
    Established Member Two Rings Black-Forest's Avatar
    Jan 09 2016
    Mercedes 600SL, 190E 16V, 03 JCW, 04 Dinan Mini Cooper
    PNW
    You are missing a clamp on the stud which holds the 2 trans cooler lines. As for the oil leak it appears to me to be coming from the lower pan.
    Old enough to know better but young enough not to listen...
    Dec 16 2014
    Irvine, CA
    With this much oil it could be from anywhere. Could be cam seals, valve covers, oil pan, oil filter housing. You will need to clean it all up and then find the leak.
    May 20 2010
    Quote Originally Posted by Black-Forest View Post
    Thanks! I'd grab it from the local U-Pull-It yard, but the sole 2.7 is laying flat on the ground. I'll try to clean it up a bit more to clear up.
    Quote Originally Posted by Kaane View Post
    Alright. I'll see what I can do early in the morning. Probably not going to be able to get good pics at all though. But I shall try.
    May 20 2010
    Realized I never followed up. Oil leak was from a hole punched in the upper oil pan. Appeared to be punched by a pry bar in an attempt to get the serpentine belt on the alternator, rather than using the proper tool on the tensioner.
    2016 A6 TDI Prestige - Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige / Ecru-Brown interior
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD
    2007 A4 2.0T quattro - Gone but not forgotten
