Results 1 to 8 of 8
    Apr 15 2014
    Ottawa/Gatineau Canada
    hw the hell do you get the plastic off around the e brake??? (not the tip piece)
    I dismantled a B7 today and could not get the lower plastic off the e brake so I could slide the center console out.
    I ended up just unbolting the entire brake assembly and removing it with the center console.
    I want to figure this out for when I install everything in my B6 and have to remove my B6 handbrake.
    Anyone?
    2004 A4 Avant Quattro. (H&R springs, S100 Nav unit, Neuspeed Cat back, Torque solutions Snub mount, Thor Skid Plate, APR Stage 1, 18" S4 Rims, 2X Podi / Oil Press / Oil Temp / Boost/VAC, Full LED interior, Backup Camera/Screen, Upgraded 2.0 Coil Packs, Vag-Com, B7 Center console/B7 Hand Brake, B7 Aero wiper arms B7 rear headreasts,APR Carbonio intake, Fan washer sprayers,
    2014 VW Tiguan. (bone stock)
    Apr 15 2014
    To be clear.. I am speaking of the plastic piece that is still on the handbrake in this pic.
    Veteran Member Four Rings Gosser's Avatar
    Jun 05 2013
    2005 A4 1.8QMT, 2006 3.2 Sedan and Wagon auto, 2004 S4, 1990 300zx TTRHD, 1988 Buick Lesabre T-Type
    Ottawa
    You should give up and sell it to me :p
    Sorry I cant be of any help, but where did you source the console from?
    2007 RS4 Avant
    2006 A4 2.7 MT Avant
    2007 A4 2.0 AT Avant
    2013 Q5 3.0 AT - Wifes
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    You have to have the center console completely loose then you will able to wiggle it free. I remember this being a pain when I did the swap.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    I had the same problem, ended up tearing up mine and had to source a replacement, which I haven't installed yet.
    Here's a pic of the inside.
    2005 A4 USP (Gone)
    2012 S4
    Veteran Member Four Rings agentsmith988's Avatar
    Fry Sauce, UT
    I think I used two flat head screw drivers to pry those two clips away from the handle assembly at the same time. Then the entire thing slid forward toward the dash. Definitely the worst part of the console swap.
    - Steve
    NKAWTG
    8V S3 Prestige | Sepang Exclusive Edition | APR Stage I HT | APR Carbon Intake | CTS Res Delete | H&R RSB 25mm | EMD 10mm/17.5mm Spacers | HomeLink Retro | Euro Aspherical Wing Mirrors | OsirUSA O-Shift EX Paddles
    Apr 15 2014
    Quote Originally Posted by Gosser View Post
    B7 part out on Kijiji :)
    Apr 15 2014
    Quote Originally Posted by CardFan View Post
    Thanks, this pic made it easy.
    I just did it on a B6 and a B7 handle, same process.
    Just pry back the two tabs in the pic and pull her off ;)
