Results 1 to 40 of 73
    Mar 28 2009
    2003 allroad; 2017 VW Golf Sportwagen 4Motion; 2008 Chevrolet Suburban
    Essex, VT
    SQ5 - H&R -1 Springs
    Just had H&R -1 springs installed on my 2014 SQ5. WOW! They transformed the car.
    Drop was 1.5", so the gap from the tire to the fender lip went from 4.375" to 2.875".
    Height from center of hub to fender lip went from 18.5" to 17".
    Install time was 6 hours, though my tech said he could now do it in half that time.
    Alignment done and perfect, no other mods or parts needed.
    Impressions:
    1 - Significantly reduced the body roll that was present with the stock ride height. (Simple physics says you reduce the roll center and you reduce the roll.) The car used to roll, then take a set when cornering, a little disconcerting after driving my lowered, Stage 2 `03 allroad. Now, it corners flat. No other mods needed. My business partner says it drives like his `12 S4.
    2 - No adverse change in ride smoothness or comfort. Wife says it's just as comfortable as before.
    3 - Like the lowered height for entry/exit.
    4 - Looks like it was designed to look (now is the same ride height as Europe).
    Worth every penny and recommend it to all.
    Mar 28 2009
    Essex, VT
    Impressions:
    Worth every penny and recommend it to all.[/QUOTE]
    Veteran Member Four Rings ThunderDent's Avatar
    Mar 14 2012
    2010 Ibis R8 Coupe 6MT V10 // 2015 Sepang (Stage I) SQ5 // 2018 Galaxy Q7 (Wifey’s)
    Ona, WV
    Glad to hear it man.
    Looking forward to my install. My KW springs arrived last week and my Alu Kreuz and sway bars should be here by Friday.
    I despise my SQ5 body roll. Suspension is the one large draw back to an otherwise great vehicle.
    Current Stable:
    •2010 Audi R8 V10 Ultra Ibis White—Black/White Stitching (6MT)
    [Nemesis/APR/Carbon Fiber/GT/Euro/LMS]
    •2019 Audi RS3 Nardo Gray—Black/Red Stitching (S-Tronic/Daily)
    •2018 Audi Q7 Prestige 3.0T Galaxy Blue—Black (Wife’s Ride)
    •2018 VW Golf S (Daughter’s Ride)
    Past Whips:
    •12 WRX Dark Gray Metallic (6MT) •11 Audi Q5 Ibis White (APR Stg 3) •12 VW GLI Tornado Red (DSG) •16 Audi Q3 Hanian Blue •15 Audi SQ5 Sepang Blue (EPL Stg I) •19 VW GTI SE
    Mar 28 2009
    Essex, VT
    Quote Originally Posted by ThunderDent View Post
    I thought I was going to need sways and alu kreuz, but I'm really happy with it just as it is. Not going to do any more.
    Veteran Member Four Rings EYE4SPEED's Avatar
    Jan 14 2008
    Macan Turbo, Cayenne Diesel, Audi Jr Quattro
    West Coast of Michigan
    Would you say two or three finger gap? I like the look and am thinking of raising to 4 fingers from two.
    FS: Audi TT 225Q Roadster
    Mar 28 2009
    Essex, VT
    Quote Originally Posted by EYE4SPEED View Post
    Depends on how fat your fingers are. That's why I gave the actual measurements in inches!
    Jul 10 2014
    -1 FTW! I noticed a little more "bounce" compared to stock, but the -1's get a 9/10 IMO... Older Pic:
    May 27 2016
    Atlanta
    Sent from my Nexus 6 using Tapatalk
    Veteran Member Four Rings VroomVroom's Avatar
    Jan 03 2007
    SF Bay Area, CA
    Wow! That sure looks like more drop than I got from the same springs on my '13 Q5.
    I'm in the research stage for my S, but I keep coming back to HR's and Bilsteins. This may have to happen.
    --Jerry || 2020 SQ7 Pr, GW/Black/BO (His); 2018 S5 Cab Pr, Daytona/Red (Hers)
    Suspension || H&R Springs - 29001-3; Bilstein B8 Dampers - 24-145985 (F) & 24-145992 (R)
    Wheels & Tires || BBS CI-R - CIR 0501 BPO, 20x10 ET25 Satin Black; Continental DWS06 275/40
    ...Formerly: '16 SQ5 '13 Q53.0T '12 Q5 3.2 '08&'06 A4 Avant 3.2.
    Active Member Two Rings Jpaisa73's Avatar
    Apr 01 2016
    Quote Originally Posted by VroomVroom View Post
    I love it!
    2015 SQ5 HR Springs HR Spacers Xpel
    Jan 03 2007
    SF Bay Area, CA
    Quote Originally Posted by Jpaisa73 View Post
    I love it!
    Gorgeous machine! Kudos.
    Apr 01 2016
    Veteran Member Three Rings turbojayc's Avatar
    Sep 11 2015
    Figured I would chime in.... H&R Springs as well. IMHO, the way the car should sit from the factory.
    2023 S3 - Daytona Grey Pearl | H&R Sport Spring | 19" Rotiform OZR | Unitronic Stage 1+
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Mar 28 2009
    Essex, VT
    Quote Originally Posted by turbojayc View Post
    That's the way they are in Europe. Audi (and others) get around the CAFE rules by classifying the Qs (and other SUVs) as "light trucks" so it doesn't screw up their corporate fuel milage stats. And, then they have to raise the ride height to "satisfy" the light truck requirement. So, dropping these 1" is just bringing them back to their original design.
    Apr 01 2016
    Wow that black must look nice in person, im sure photos dont do it justice.
    Nice rig!
    Sep 11 2015
    Nice rig!
    Thanks man
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Jul 10 2014
    Quote Originally Posted by BillVT View Post
    That's what I originally wanted to do was go "Euro height"... But now I am eyeing C/O's... Cuz MOAR LOW.
    Sep 11 2015
    Quick question for people running H&R springs on their SQ's. Anyone having noise issues? When I first had them installed they were making a clicking sound when turning slowly. Turned out the springs just needed a ton of geese to keep the springs lubed up. That issue has since been fixed.
    Now I find I get a rattling sound over all bumps. It's really annoying. Sounds like i'm driving my 2001 slammed Civic SiR from back in the day. What can be causing this? Suspension and components are all stock otherwise.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Mar 28 2009
    Essex, VT
    No issues with mine; about 250 miles on them.
    Apr 01 2016
    $1500 miles on mine no issues no noise whatsoever
    Sep 11 2015
    Actually had local indy shop I got o have a look and test drive. Turns out its not the springs at all, but the mechanic is thinking is a bit of body flex and recommends the eurcocode alu kreuz.
    So we'll see.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Go with the full 034 MotorSport package. Their X-Brace is a little better than the AK, IMO.
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    Quote Originally Posted by SQive View Post
    What's the difference between the AK and the 034 X-Brace? I had been planning to just go with the AK since it's $75 cheaper and appears to be identical.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Apr 26 2014
    DFW
    It's just a little beefier. It also fits both B8 & 8.5, but that doesn't really matter unless you plan on moving it from one to the other.
    Mar 26 2015
    New York, NY
    Good to know. I may still cheap out and save a bill with the AK and free shipping though!
    So we'll see.
    Are you sure there isn't something else going on with your springs installation? I definitely didn't have anything rattling like a slammed Civic when I was on springs only. That doesn't sound like something I would expect the AK to fix.
    Current
    Past
    Sep 11 2015
    Quote Originally Posted by riceboy22 View Post
    I may have exaggerated a bit. lol.. On the test drive it makes no noises over speed bumbs, road bumps. Nothing. Its when I come to a complete stop, it clicks. let off the brake again and it clicks. Backing in on an angle. it clicks. It's as if anytime the chassis moves/rolls whatever you want to call it. it clicks. I dunno. Going to hoist it up and see, just didn't have time the day I went in quickly. All in all. Springs have been ruled out.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Didn't have any issues over 7000 miles
    $1500 miles
    say what
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Apr 26 2014
    DFW
    Quote Originally Posted by q5 dave View Post
    say what
    That's the new measurement, dollar-miles. It loosely equates in the smiles-per-gallon, divided by the square of the dollars spent modding.
    ...at least that's my guess.
    Mar 26 2015
    New York, NY
    You're probably way more in-tune with your car than I am. Most of the time I've got an occupied baby seat, a stroller in the trunk, and a dog all making some sort of noise. I'm more concerned if I don't hear strange sounds coming from somewhere LOL.
    Is the clicking sound coming from any specific direction that you can tell (e.g., front or back)? Is it loud enough that a passenger not listening for it would notice?
    Current
    Past
    Sep 11 2015
    My backseat/trunk set-up sounds exactly like yours. Rocking a Diono RXT for the 4 year old, Graco Snugride for the 9 month old. Uppa Baby G-Luxe or Vista at any given time. That stuff rattles like crazy. Dog doesn't come in the car much anymore. lol...
    Anyways, the clicking is coming from the front. Maybe something loose on the brakes, we thought. Anyways, until I get it on a lift we don't know for sure. Just don't think it's spring problem.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Mar 26 2015
    New York, NY
    Yeah, something with the brakes sounds plausible given what you're describing. One click or multiple clicks each time you stop?
    OT: Do you find that you have enough space in the car with two kids? We've got a second on the way and occasionally wonder if we should have gotten something bigger. Maybe I'll be allowed to upgrade to an SQ7 one day LOL.
    Current
    Past
    Sep 11 2015
    One click, per stop/brake.
    I find it more then enough room. The rear facing snugride makes it a bit tight for the front passenger, but my wife is small so she doesn't care. Plus once he's in a forward facing seat, it will be fine. My daughter sits behind me and it's no problem. Trunk space I find ok as well. The way I see it, it's just less crap I have to haul around. I came from a 12' Toaureg and it had tons of space, but found it too big, too slow and coming from a 135 coupe, I felt like an old man. The SQ5 makes me feel alive again. My wife complains when she has to sit in the back with the kids to feed my son. But I basically tell her it's too bad. She can get a bigger car if she wants lol.. She's drives an X1 and its tiny.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Mar 26 2015
    New York, NY
    My (admittedly probably useless) internet diagnosis is a loose brake pad. Let us know what you end up finding out once you get it on a lift and poke around. It doesn't sound suspension related like you said since you don't hear anything over bumps or in turns.
    OT: I guess I'll wait and see what the SQ7 looks like when it makes it over to North America. If it looks good, then I'll need to find more reasons to make my wife sit in the back seat between the kids LOL.
    Current
    Past
    Sep 11 2015
    Ya, we"ll have a look once its on the hoist or in for a GIAC Stage II Whatever comes first.
    SQ7, looks nice, just big IMHO.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Mar 14 2012
    Ona, WV
    I second the loose brake pad. That happened on my old Q5 once and it just made a clicking sound when it would move. Took me forever to figure out what it was.
    I only have one baby seat in mine, but I keep it in the center. Still rear facing. My wife bought a bigger one and has it in her Q3, but while rear facing it has to be in the middle. They just take up so much room.
    Once we can flip it (which with today's safety standards should be by the time they hit middle school), there will be plenty of room.
    Heck my wife's grandma should technically be in a booster seat at her height. 4'11"
    I'm looking at potentially one of the Audi booster seats. But probably will not ever get one. But it'd be cool!
    I wonder if these are leather or cloth?
    https://shops.audi.com/en_GB/web/zub...ly/child-seats
    Current Stable:
    Past Whips:
    Sep 11 2015
    Those Audi booster seats are awesome.
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Mar 26 2015
    New York, NY
    I'm going to order one of those child seat underlays. The ones I find on Amazon always have people complaining about staining and/or melting onto the leather. Hopefully the Audi one doesn't have either of those problems.
    Current
    Past
    Established Member Two Rings Hrp783's Avatar
    May 07 2014
    F-150 Larriett, Infiniti G35 sport
    Austin Texas
    Where can I get these?
    Veteran Member Four Rings DBFL's Avatar
    Jan 01 2016
    2016 S4, 2018 Ford F-150, 2022 Audi SQ5, 1982 Audi Coupe
    Tampa Bay
    What is the part number for the H&R -1 springs? When I look on their website I only see the sport springs (part 29001-3) listed. H&R states a drop of 1f .8r for the sport springs. I like the look of what I see in this thread.
    Thanks
    -Daniel
    2016 S4 P+ | 6MT | Sports Diff. | Tech. Package
    S4 Build Thread
    Mar 28 2009
    Essex, VT
    Quote Originally Posted by DBFL View Post
    Thanks
    -Daniel
    That's the correct part number and spring Daniel. Mine went lower than their spec as you can see but it wound up perfect!
    After about 3K miles, I think they are great. A "must-do" to transform the car.
