Results 1 to 19 of 19
    Registered User Four Rings
    Oct 27 2007
    NA
    M'AUTOLITE LED Headlights/foglights $40 OFF - INSTANT REBATE OFFER by HIDCONCEPT.COM
    Happy Memorial Day to all AZ members!
    We are offering $40 INSTANT REBATE OFFER on M'AUTOLITE LED headlights/foglights from May 28 - June 3, 2016.
    USE Coupon Code: MAUTO40
    M'AUTOLITE LED lights use true PHILIPS Luxeon MZ LED chips to produce 360 degree light distribution and 2500 lumen without requiring a bulky cooling fan.
    Installation is very straight forward and plug & play simple without any custom wiring or cutting involved.
    Flexible 100% COPPER (Cu) Weave cloth heat-sink would make the installation much easier.
    Fully compatible with 9005[/URL]
    TECHNICAL SPEC
    Type : H1, H3, H4, H7, H8, H10, H11, H13, 9005, 9006
    2500 lumens per bulb
    100% Copper (Cu) flexible weave cloth heat-sink
    Color: appx. 5500K, pure white
    Application: Head light, Fog light
    Estimated lifespan: 50,000 hrs
    Voltage: DC12V - 24V
    Input Current: 1.6A (DC 12V)
    Power: 40W set (20W /bulb x 2)
    Photos:
    Comparison photo showing halogen fog vs. M'AUTOLITE fog with low beams on.
    Photos taken by AZ member: fromario (Thanks for taking photos) from this thread.
    1. M'AUTOLITE LED lights on fogs w/DRL only.
    2. M'AUTOLITE LED lights on fogs w/Philips X-tremeVision D3S bulbs
    3. M'AUTOLITE LED on passenger's side vs. Philips 2700K Yellow LED on driver side
    4. M'AUTOLITE LED on passenger's side vs. Philips 2700K Yellow LED on driver side
    Porsche Macan: Halogen vs. M'AUTOLITE LED comparison shot
    If you have any questions, please feel free to contact us at 1-888-579-5917 or email us at [email protected].
    We have friendly staff members who love cars :D
    Senior Member Three Rings Italiano's Avatar
    Jul 27 2009
    2012 BMW X5, 1979 Corvette
    Charleston, SC
    what is the cost to replace OEM Fogs on a 2014 S4 with this set up?
    BTW the link you posted is broken
    2014 S4 (B8.5) APR Stage II+ ll APR Pulley upgrade ll APR Exhaust ll APR TCU Upgrade ll 20% tint
    Mar 21 2015
    ^ Link works fine for me. H8 bulbs I believe and they are 109 - 40 rebate
    Nov 28 2015
    Montreal, QC
    no soft code, plug and play guarentee ?
    I'm asking because i bought ebay exact same led and it threw a code. I like this design, but looking for a 100% trouble free solution.
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    I have these, no soft codes, no error codes, very clean light! Looks great and these guys are great to do business with!!
    Sent from my SM-G935V using Tapatalk
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | Jokerz Ported SC| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    What r the B8.5 (oem) headlight Kelvin color?
    double thumbin' it!
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    Mar 21 2015
    Quote Originally Posted by quietcropduster View Post
    double thumbin' it!
    I may be wrong but I believe it's 4300
    Feb 21 2015
    Ohio
    Gotcha, ur correct just bought some H8s for my B8.5 S4.
    double thumbin' it!
    Nov 28 2015
    Montreal, QC
    fantastic.. ordering a set :)
    Jan 03 2010
    Endicott, NY
    I have the cornering lamp feature enabled on my car (fog light fade in and out when turning). Will these LEDs work properly with this feature?
    Oct 27 2007
    NA
    Oct 27 2007
    NA
    Quote Originally Posted by Kontroversen View Post
    Cornering light on B8.5 would not work properly.
    You need to either disable the cornering light feature and use cool LED's or cornering lights with dull yellow halogen. :D
    - - - Updated - - -
    Quote Originally Posted by Jroyalty7 View Post
    No fault code for sure. Otherwise, we would not advertise it on this forum.
    Oct 27 2007
    NA
    FAQ's:
    How are they compared to other competitors?
    --> I'm not 100% sure what other competitors' would be like but I'm not a big fan of ones with bulky cooling fan because it not only takes up too much space, it also may fail before the LED lights.
    Is it really brighter than halogen?
    Yes, it is. Halogen light is appx. 1100 lumens. These are 2500 lumens. See comparison photos actually taken by us to get an idea.
    Happy Memorial Day, Everyone!
    Jul 10 2015
    SATX
    You got me! This seems to be lowest price point for these so I picked up a pair. I can't wait to actually start using my fog lights! The stockers are worthless.
    I was tempted to pickup a set for my 05' Allroad but will wait for now.
    Feb 21 2015
    Ohio
    Quote Originally Posted by mike@hidconcept View Post
    - - - Updated - - -
    Why would this cause issues with the cornering lights, it's a different bulb right? Please explain lol
    double thumbin' it!
    Mar 21 2015
    double thumbin' it!
    These are not meant to fade I believe. When using the cornering feature the bulb fades in and out.
    Mar 05 2014
    2020 SQ5
    PDX
    Might have to pick me up some, great deal.
    2020 SQ5 Quantum
    Oct 27 2007
    NA
    double thumbin' it!
    On most of Porsches with cornering light, did not have any problem but for some reason, B8.5 did give error message.
    It is probably because the cornering light dims on/off very slowly/gradually.
    Jul 10 2015
    SATX
    Just wanted to post my experience with these LED's and HIDConcept. Shipping wast fast. Ordered on May 30, shipped next day and arrived 2 days later.
    Packaging was too notch. Each light was secured with foam cut outs.
    Install: Despite being a bit apprehensive of the rear approach (that's what she said - Giggity) I went for it. Too many people swore that this was easier and less sketchy with potential for the fog grill breaking. Lock the steering wheel to opposite side that you are working to expose torx screws. Both driver and passenger side I took out the two torx screws on the wheel well to gain access but could have managed with just one in my case as my hands are smaller and the liner is quite flexible. New lights went in easy. I would recommend you verify complete seating and sealing of the light from the front with a light (phone light worked for me) to ensure all 3 holding tabs are present. Once The new lights went in I connected the harness. After connecting there was quite a bit of wire slack and I didn't want them bouncing inside the bumper so I used double sided Velcro to secure them. Passenger side I secured excess wires to a black wire protecting hose nearby. Driver side I secured the loose wires to themselves by doubling them up. I then secured the bundle to an A/C line. The last step was fanning the heatsinks. Passenger side was no problem. Driver side had a rubber hose in close proximity and I fanned the heatsinks away from this so that it did not touch the hose.
    One other tip that worked for me was to use my phone light and actually place my phone inside/behind the wheel well while I worked. This gave great visibility and prevented a blind approach to insertion while freeing both hands to work.
    Appearance:
    Very bright! A bit more blue than the Headlights or DRL's but not annoyingly so. No error codes. I will actually use my fog lights now and will no longer have light envy when I see my wife's factory LED fog lights in her Infinity QX60 ;)
