I'm trying to do a valve body on my 2003 TT. I'm stuck at getting the wiring harness apart at the trans case. It first comes apart with a clip. But then you have to unscrew a bolt that allows you some play in the wires that go into the trans case but the connector is still too large to fit through the hole. It has to come apart more but there is so little room, I can't see well enough to figure it out. Anyone know how to get it apart so I can slide the remaining harness through the case to remove the valve body? It's an 09G transmission which is also used in some VWs.
