Results 1 to 13 of 13
    Established Member Two Rings SacSantorin's Avatar
    Aug 18 2015
    Almost Canada, WA
    Frankenturbo F21 PSI question
    I'm looking for some F21 owners to weigh in on how much PSI of boost there f21 is putting out. I'm about done with my tuning with motoza and I'm not making it to 20 at all. Spikes at 19 and holds at 18. Seems funny since my B6 with APR 1+ is spiking at 23 and holding 18-20 on a K03S. I'm concerned I have a boost leak or maybe an exhaust leak at the manifold. Any thoughts?
    2000 Audi A4 1.8T | Santorin Blue | Frankenturbo F21L Mixed Flow | Motoza 550cc Tune | Custom 2.5'' Exhaust w/ Milltek Downpipe | 3'' MAF Housing | 3" Ebay Testpipe | CX Racing FMIC | B6 5 Spoke Wheels | ECS Boost Guage | OEM RS4 Grill
    Dec 05 2007
    Adjust and tighten your wg actuator rod locking nuts. Common issue with the FT. You will get faster spool and more boost. You are losing it from having a loose wg flapper.
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Have you performed a boost leak test? An improperly loaded wastegate could be the cause but so could other things. Start basic then go from there.
    Sent from my LG-H815 using Tapatalk
    Aug 18 2015
    Almost Canada, WA
    Thanks Seerlah! I'll look into that asap, I've never done a wastegate adjustment before, in your experience would it be easier if I pulled the turbo from the car?
    Aug 18 2015
    Almost Canada, WA
    Quote Originally Posted by Believer View Post
    Ya i have been meaning to do a boost leak test. I just moved to a new state and I'm still in the process of unpacking. I may just make a new tool to test it instead of trying to find my old one. If i recall it cost me like $3 to make from Home Depot. I was just looking for some thoughts on where I should be sitting at with boost as a baseline.
    Oct 24 2011
    New Jersey
    So on the 2.5 bar MAP Dave had me spiking 21ish then holding 20. With the 3 bar MAP I'm spiking 23 and holding 22. This was until I developed a pre turbine leak and now it's not boosting quite as much
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Quote Originally Posted by SacSantorin View Post
    Have you actually asked Dave what the tune is shooting for? It might just be that this is exactly how he's set the file up. I've done the same on my F21, we peaked at 19, held 18. Above that it was just blowing a bunch of hot air that gave no performance gain. Still makes somewhere close to 300whp on e85. I wouldn't get too hung up on not hitting boost in the 20's.
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Jun 30 2008
    Erie, Pennsylvania
    I don't know about Mitch, but in my experience, it is much easier to do with turbo and manifold in place. I just drop the cat off the turbo a little ways (3 nuts and disconnect the downpipe-trans mounting).
    I mean, of course the adjustment itself is easier if the turbo is just sitting on a table, but removing and reinstalling the manifold or turbo to do this is a lot of unnecessary work. The adjustment isn't visible, but it is plenty accessible.
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    Quote Originally Posted by G-Ride View Post
    That's exactly what I'm hitting, but I know Dave wants to go a bit higher. I'm on E85 with the CTS fmic. Waiting on the second revision too. I think 20 PSI is the goal for now though.
    I know Dave said my waste gate spring was softer than usual, so my boost was around 16 on the base file. He increased the N75 duty cycle a bit to get up to 20. I think we're all in the same neighborhood of boost for stock rod setups.
    Sent from my VS990 using Tapatalk
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
    Sep 24 2010
    2001_Corvette_Z06
    Costa Mesa, SoCal
    This isn't a problem I've heard of for FTs, or at least the F21 longitudinal variants.
    OP: Your boost is pretty typical of how Motoza tunes. On 91 octane he put me around what you're boosting. Of course as mentioned by others a boost leak can also make an impact.
    2001 Corvette (C5) Z06
    Veteran Member Four Rings AudiSport12's Avatar
    Feb 17 2006
    Coastal Georgia
    Log on the Motoza software what the requested and actual boost is. I'm touching 21ish and holding around 19. I do need to go back for another revision as I'm seeing some boost surging in the higher RPMs.
    2011 B8 S4
    2003 Z71 Tahoe
    2000 B5 S4 - Sold
    2001 B5 1.8TQM F21L - Sold
    2000 B5 1.8TQM - RIP
    2000 C5 4.2Q - Sold
    1997 B5 1.8TQ - Sold
    Aug 18 2015
    Almost Canada, WA
    Quote Originally Posted by AudiSport12 View Post
    Ya i did some logs yesterday and actual and requested seem to be matching up. Sometimes the car just feels sluggish though, I think its time for a new clutch. The stock one hasn't started slipping yet but I think its gotta be close.
    Senior Member Two Rings PsorianoPre99A4's Avatar
    Dec 13 2015
    B8.5%20AR%2014%27%20P %20
    PNW
    Could that be an issue of why i'm not hitting 20-22 psi and at 10 psi?
