Results 1 to 9 of 9
    Mar 21 2016
    69 Nova
    California
    Just did my 3.0 timing belt, now check engine light is on...
    Title is pretty self explanatory. I just scanned it with my snapon scanner, nothing vagcom, but it should still be correct.
    Anyway, I got a P0343. I didn't have my phone or anything to write with but it said something like cam angle sensor bank 1- high.
    So now what? Do I have to tear everything apart again?
    I drove it around the block before I scanned it, it drove fine, seems more peppy than before, but it's been a couple weeks since I've driven it.
    So should I stop driving it?
    12 S4 Quattro 6 Speed
    04 A4 3.0 Quattro 6 Speed
    69 Nova with a bunch of stuffs
    19 Sportster 883
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    Cam shaft sensor. Did you use the timing cam shaft locks?? Did you make sure everything was TDC??? probably your sensor went bad.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Mar 21 2016
    69 Nova
    California
    Yeah, I bought the tools and followed this guide:
    http://www.audiworld.com/tech/eng110.shtml
    It said tighten the cam locks to 10 ft lbs, but I went tighter because I was scared they'd move, lol.
    Unfortunately when I was tightening the bolts in the ends of the cams, the exhaust cam on the passenger side did move a little. That's why I'm afraid I have to tear everything apart again.
    But I had the engine running for at least a half hour while bleeding the cooling system, flushing the power steering, and then going to get gas because my low fuel light was on.
    If the cam moved and/or the timing was off, would the engine even be running? I figured the valves would have hit the pistons if it was off...
    19 Sportster 883
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    Quote Originally Posted by DarkoNova View Post
    If the cam did move with the cam lock installed, it would be a fraction of a degree at most. Not nearly enough to cause piston to valve contact, and more than likely not enough for a sensor to see it. As long as you performed every step as described then you can be pretty confident that it's probably a sensor on its way out.
    Mar 21 2016
    69 Nova
    California
    Quote Originally Posted by MoparFreak69 View Post
    Well thanks, that makes me feel better.
    Which side is bank 1 and which side is bank 2? Google says the driver's side is bank 1, and if that's true, then it probably is the sensor since the cam that moved a little was on the passenger's side.
    19 Sportster 883
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Bank 1 is on the riders side (same as a 1.8T). Bank 2 is the drivers side.
    Jul 28 2014
    SACRAMENTO
    04 B6 A4 USP 2.7t
    Mar 21 2016
    69 Nova
    California
    Well shit, that doesn't look good. Guess I'll swap sensors from one bank to the other and hope the code changes.
    19 Sportster 883
    Mar 21 2016
    69 Nova
    California
    Well I swapped cam sensors, I took the intake cam sensor from the driver side and swapped it with, I think, the intake cam sensor from the passenger's side. I did it while on break at work so I'm not too sure which one I took out of the passenger side.
    Anyway, both of them were actually loose. The bolt holding them in was backed out a few threads and I could easily pull them out a millimeter or two. Not sure how that happened since I didn't mess with them during the timing belt job, but I swapped em, tightened em up, cleared the code, and after 40 miles or so, it hasn't come back.
    Hopefully it was just because the sensor was loose.
    19 Sportster 883
