Results 1 to 8 of 8
    Senior Member Two Rings dgreeen's Avatar
    Apr 09 2016
    CBRF4i
    US
    Front Bumper Removal
    So I recently swapped my grill out for the rs style grille
    But when I went to put everything back together for some reason the side of the bumper won't stay in the clip
    It stays in for a few minutes but when I go out to drive its sticking out again.
    Tried pulling it out and sliding up and pushing in after but still no luck.
    Possibly someone came across the same issue?
    Established Member Two Rings thrill23's Avatar
    Apr 30 2016
    OEM Parts
    Miami, FL
    Quote Originally Posted by dgreeen View Post
    I can send you a PDF on specific instructions. You probably missed a step. What's your email?
    Apr 09 2016
    CBRF4i
    US
    Just pmed you
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    There's some liner screws that go in there. You get them into the right holes?
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Senior Member Two Rings MrTylerRaines's Avatar
    Feb 21 2015
    Ohio
    I would take it all back apart and re-evaluate and try again. Sometimes something as simple as a piece of liner can be in the way. Cheers.
    Mr Tyler
    Feb 24 2013
    CA
    Theres a tab that you need to pull forward. Its bolt tab
    Senior Member Two Rings redeye_jedi's Avatar
    Dec 12 2015
    Sk8teboard, Audi B8 A4 Quattro stg2
    I have the exact same problem with my b8.
    Veteran Member Three Rings Sedan Guy's Avatar
    Mar 10 2005
    Amani War Bear and a Chocobo
    Orange County, CA
    Check to see if the inner bumper flap was not pushed in front of the bumper retainer. This can be overlooked when putting the bumper back on. Just pull that flap piece over the retainer and align it with the hole for the fender lining screw. This is on my allroad. Im sure it will be similar for sedans
    This piece, make sure it sits over the retainer
    2013 Audi allroad thread | RS5 4.2L V8 conversion by Pacific German
    Instagram: ilevel_audi, ilevel_wagon
