Results 1 to 10 of 10
    May 04 2016
    Naptown
    Question Ignition taking several seconds to turn over
    Searched for details, but my keywords must be lacking.
    110K 2009 B8 Quattro.
    For years my trusty B8 has started immediately with a push of the keyfob. For the past 2 weeks I have to hold the fob in for 2-5 seconds for the car to turnover. I don't suspect a battery issue (replaced about 5 months ago), could this be the starter?
    Background, I am also throwing the P0299 code and will require a mod to my waste gate actuator or a new turbo in my future. Depressing, but not sure this is tied to my ignition issue that just popped up.
    Any ideas?
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    Sounds like your timing tensioner. Check out my thread: http://www.audizine.com/forum/showth...-Now-with-Pics
    Are you sure that's the 'only' code you're throwing?
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    May 04 2016
    Naptown
    Quote Originally Posted by Allowencer View Post
    Thanks, will take a read through your thread. Appreciate the pointer.
    Yes, also got P0016 Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
    Jun 12 2013
    Ouch man, sorry to hear. Yeah, your timing tensioner went.
    Build Thread
    Feb 24 2013
    CA
    Hmmm, i only have an issue with turning mine on in the mornings every now and then. It doesnt want to start so i turn it back off and it starts the 2nd time. It happens occasionally but i think its the hpfp or the fuel filter causing it.
    Established Member Two Rings HenrikMeister's Avatar
    Apr 03 2016
    Norway
    Had the same issue. I ignored it for about week, suddenly the chain went, after that I couldn't even start the car... No compression at all. All fixed now tho, with new timing chain and tensioner
    Edit: also had P0016 bank 1 sensor a
    May 04 2016
    Naptown
    [QUOTE=HenrikMeister;11652275]Had the same issue. I ignored it for about week, suddenly the chain went, after that I couldn't even start the car... No compression at all. All fixed now tho, with new timing chain and tensioner
    Thanks for the info. Did you do it yourself or take it to a garage? How much did it set you back, if you don't mind?
    May 04 2016
    Naptown
    Well, it's been a good run to 110 with only the oil consumption issue.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    Yeah man I wouldn't drive the car until that's resolved. Sorry to hear about your issue. These are getting more a lot more common as the cars age.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Apr 03 2016
    Norway
    [QUOTE=indysyc;11652362]
    Quote Originally Posted by HenrikMeister View Post
    Took it to the garage. Don't have the time or patience to do it myself.. Im from outside states so price may vary. In USD I payed bout 4100.
