Results 1 to 16 of 16
    Active Member Two Rings peanutloc's Avatar
    May 26 2016
    OC
    CA: 2008-2014 Audi H&R Street Coilovers for A4 S4 S5 Quattro Avant Cabrio
    Up for sale is a 2008-2014 H&R Street Performance Coilover Suspension kit (Part # 29092-1) for various 2008-2014 Audi Models.
    $850 obo
    Coilovers were used for about 25k Miles/1 year, right side strut cartridges have been replaced and are NEW (hit a pothole on the freeway and replaced immediately.)
    No major damage, just normal wear from road use/daily driving, just could use a little cleaning.
    Selling because the A4 they were used on is now sold.
    Ride quality is a huge upgrade from stock, these retail for over $1,500+ new.
    PICS:
    FITS:
    -2009-2012 Audi A4; Quattro; Avant;
    -2010-2012 Audi A5; Cabrio Cabriolet;
    -2008-2012 Audi A5 Quattro;
    -2010-2012 Audi S4;
    -2008-2012 Audi S5 Base;
    -2010-2012 Audi S5 Cabriolet
    Can meet around Westminster/Huntington Beach Area
    Features:
    Take command over your handling with H&R Street Performance Coil Over Shocks
    Fully adjustable for between 1" and 2.5" of drop
    H&R custom crafts your Street Performance Coil Overs for a direct replacement fit with no modding needed
    Stay at the top of the height spectrum for greater comfort or dip down lower for a sportier feel
    Cutting-edge monotube shock design that's fully threaded for easy height alterations
    Progressive spring rates for the perfect balance of steering bite and cruising comfort
    Springs and shock are tuned to pair perfectly on your vehicle
    Ships fully-tested and ready for action
    Manufactured in Germany
    Your HR Street Coilovers include a Lifetime Defect Warranty
    Description:
    Road conditions change throughout the year, and so do your driving styles. Unfortunately, traditional lowering kits leave you stuck at a specific height for one specific result on your specific vehicle. Break free from the mold with H&R Street Performance Coil Over Shocks. Adjustable between 1" and 2.5" for most vehicles, they give you the room to fine-tune your drop just the way you want it.
    Forget about all that slop in your steering wheel. Once you sink your center of gravity down with H&R Street Coilovers, your body roll practically disappears and your handling definitely tightens up--all while maintaining an easy-going ride quality you won't dread driving on a daily basis. Anytime you get the itch to push it harder, simply drop down lower for more aggressive response.
    H&R Street Coil Overs are designed, built and tested in Germany. Custom configured for your vehicle, the valving in the monotube shocks is tuned to complement the progressive-rate springs. Together, they creating a one-two performance punch that'll leave a permanent smile on your face. To top it off, H&R backs your Street Coil Overs with a Lifetime Defect Warranty.
    Audi 5000
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Up
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    Established Member Two Rings Kvives's Avatar
    Aug 08 2015
    Vives
    Interested, PM'd
    May 26 2016
    OC
    Replied, bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
    May 26 2016
    OC
    Bump
