Results 1 to 13 of 13
    Feb 25 2016
    Plymouth mi
    2000 S4 lost power and stalled /won't start
    I was driving on the freeway (kind of aggressively) and then I lost power. Started chugging when I hit the gas and then finally stalled out when I got off the freeway because I was losing power and now it won't start..won't do anything.
    After I got it towed home I was trying to start it and have the key in the on position for a while and then a big temperature gauge started flashing on the display. There was no signs of overheating as I was driving but check the coolant reservoir and it was empty. I have so far change the coolant temperature sensor and tried a new battery because the one in there was from 2012. I haven't had the car for very long and also have a parts car to get things from. since the battery was dead I lost access to any codes.
    It just clicks when trying to start now, it turned over once but wouldn't start. Any thoughts on what it could be?
    Jul 04 2012
    Woodbridge, VA
    Turn over click click click? Starter.
    Feb 25 2016
    Plymouth mi
    Yeah ...that would shut the car down while driving?
    Jul 04 2012
    Woodbridge, VA
    No. But sounds to me like electrical to the starter. The big picture I am thinking is maybe coolant flowed up wiring harness into ecu.
    Feb 25 2016
    Plymouth mi
    Hmm that didn't occur to me
    May 30 2015
    canada
    Check your grounds
    Feb 25 2016
    Plymouth mi
    Feb 25 2016
    Plymouth mi
    Loud hissing sound coming from driver side engine area. I think from the cylindrical silver part(?) which I don't even know what is. The car turned over again after wiggling the grounds and power around..no start yet and now hissing sound when the car is on. I have full interior power..
    Tried to upload a video but not sure if it worked
    Senior Member Two Rings czsrock1990's Avatar
    Apr 20 2010
    2001.5 Stg3 B5 S4, 2001 B5 S4
    Chicopee Ma
    Not saying this is your problem but when I was driving aggressively I blew off a hose and at one point I couldn't get my car to turn over or do anything. I had to disconnect my battery for 30 mins and then it turned over and started. Just throwing out what I experienced hoping it'll help you.
    Pearl White Stage 3 B5 S4
    Brilliant Black B5 S4
    2004 Dodge Ram Cummins (Sold)
    Silver B6 S4 - Milltek catback, VMR 708's, (Sold)
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Unplug the MAF sensor. See if it starts.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Apr 01 2011
    B5 on jack stands
    charlotte
    you have basically some kind of intake/vaccum leak. maybe through you sai
    powered by
    Hot Boi parts
    Sep 09 2014
    Grand Rapids, Michigan
    Hissing from that silver cylinder thing is potentially due to the fact that the hose connected to it looks electrical taped (based on the video) you could be leaking pressure from the combi valves. Not a huge deal. Part of your secondary air system. This won't prevent it from starting. Full interior power but sometimes turning/other times clicking leads me to believe a loose/corroded engine ground. They're located off of the passenger side frame rail. If you follow your power wire from the battery down to the alternator it should be attached to that (with a zip tie of some sort). Sometimes if they're even a little loose it can cause this issue. It can prevent the battery from charging and starter from turning over. Mine was tight but corroded internally, so if it is tight I would try cutting it open to see or even just replacing it. Generic wire from the parts store will do the same thing.
    If it's starting to go bad it will sometimes get enough ground to turn over, other times it won't. So wiggling the grounds on your firewall could just be unrelated.
    Feb 25 2016
    Plymouth mi
    Thanks for all the input everyone, I need to get a few hours to look more into it. It sounds to me like trb1 has the right ideas
