Been having a starting issue with my A5 that is getting constantly worse. Hoping someone can lead me into the right direction.
Car details:
2012 Audi A5 with 42,000 miles. 6 speed manual. Zero modifications. No Check engine lights or other error lights after startup.
Problem(s):
About two months ago my car wouldn't want to start. Press the clutch, gauges sweep, but nothing after that. Would try again and then would start. As time passed I had to attempt to start it a few times before it would attempt to start. Fast forward to now the car almost always does not want to start. Sometimes it will and then shut off after 2-3 seconds. Then it won't want to start again after a few tries. Once the car actually starts and runs past a few seconds it will run perfectly normal. Today while dealing with this I started getting more faults with TPMS, air bags, and power windows wouldn't work but all that went away once the car did turn over properly.
Did some research on here for a few days and the only thing I can somewhat come up with is the clutch switch which is also integrated into the clutch master cylinder. Seems odd that it would cause all these other issues as well. I did a scan with the Carista app and came up with these soft codes I'll post in my next post below.
- - - Updated - - -
CAN network gateway:
01314 - Engine Control Module (ECM)
01312 - Powertrain data-BUS
Ignition authorization:
01330 - Central Control Module for Central Convenience (J393)
Central electronics:
Body/convenience system:
00473 - Control Module for Electric Park- / Hand Brake (J540)
Heater & air conditioning:
03220
Instrument cluster:
Parking brake:
03182 - Position-Sensor Clutch
Parking brake:
Parking brake:
ABS:
ABS:
Engine:
P1215 - Cylinder 3 Fuel Injector (N32), Circuit Short to B+
Headlight aiming:
336388
Radio:
Radio:
02635 - Tuner not enabled / activated
