Results 1 to 26 of 26
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Front brake day!
    Installing ECS two piece rotors and akebono pads tomorrow. Reviewed the post with step by step instructions on doing the front brakes several times and have all torque specs. I have a bendpak scissor lift so i will be skipping the jack and stands part of the process. First step was getting the car centered over the lift, which i discovered was to low even at stock height. So, i put my race ramps down, the ones i use for my crx, and got the car centered over the lift. First thing tomorrow i will do the brakes, i will take a few pics of the car on the lift if anyone is interested. It is rated at 6000lbs so it should have no trouble lifting the 3900lb S4.
    Wish me luck! Ill post the results tomorrow!
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Good luck. Be careful with the scissor lift, it's not reliable at all even your car's weight is well under its rated weight. Someone in this forum reported her husband (or bf) broke his arm due to the failure of the scissor lift that comes with the car during a wheel change.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by yjypm View Post
    On the vwvortex the stock emergency scissor lift has been dubbed the Widow Maker for a reason.
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Oct 08 2015
    Quote Originally Posted by theswoleguy View Post
    This!
    Watch out OP!
    Current: '18 M3 ZCP
    Dec 07 2012
    Atlanta, GA
    Op did Say bendpak which is a lift manufacturer
    Oct 08 2015
    Didn't notice that.
    I went a bit nuts coz scissor lifts are just scary to me.
    Current: '18 M3 ZCP
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Didn't notice that.
    That and I don't think that "widow maker" is rated for 6K lbs either lol. I would never use that thing ever. I think the first thing when you buy the car is to throw that out. I would either be calling roadside or calling a life line to come get me and go home and get my jack.
    Yea lowered cars can be a PITA with lifts sometime. That's why you need air lift. Just air it up to allroad status and your good lol.
    Let me know how you like the setup. I want to do something with my setup as well. Im getting tired of having to scrub the wheels every wash even with coating on the wheels. What 2 piece rotors did you get?
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I could barely get my car over my buddy's scissor lift either. He had race ramps too. My car is lowered though.
    Front brakes are easy. You'll have them done quicker than you think.
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Front brake day!
    I've used that OEM scissor lift quite a bit. I mean, 15 seconds to lift car, then 2 seconds to put it down onto a jack stand. I wouldn't work on the car with just the scissor lift, but to get it one wheel well into the air works well enough.
    I would love to use my expensive low profile jack, but I can't get a jack stand under the pinch weld when you have to jack on the pinch weld, so I'm stuck using the scissor lift. I really wish there was a center and rear jack point on this car.
    Veteran Member Four Rings mr shickadance's Avatar
    Jul 08 2010
    tucson
    danbury
    Quote Originally Posted by cspcrx View Post
    assuming you are not using the spare tire jack, if you are, you should prolly stop the install.
    the caliper carrier bolt, the bolt that attaches the caliper carrier (not caliper) to the wheel assembly is a complete nightmare to loosen, i really ought to re-edit my DIY and say that you should get an impact gun for it.
    [CENTER]Scott
    2011 S4
    America is all about speed, hot, nasty, bad-ass speed - Eleanor Roosevelt
    Apr 04 2012
    MSP
    I'm sure OP is talking about this kind of lift which locks when it's up.
    Oct 20 2008
    Denver
    people can't read. wow!
    Jan 04 2013
    Phoenix, az
    Yes not scissor jack but an actually lift. Guys use these to lift F250s with out issue. If it was from Habor Freight I might be more concerned! Here is a picture of mine.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by AudiTFSI3o3 View Post
    What you talking about reading is over rated. We like Pics lol
    Oct 20 2008
    Denver
    Quote Originally Posted by chaos2984 View Post
    lol you mean no one's seen OP's lift before? it's all over the forum lol
    Mar 21 2015
    Really
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Quote Originally Posted by pfft View Post
    This is what I do as well, not by choice as it's the only option. There's simply not enough room to lift it with my floor jack and then slide in jack stands.
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Jan 04 2013
    Phoenix, az
    All Done! damn spring on the front of the calipers is a dangerous little b!&&$!!!! Here is a few pics of the car up and brakes done. Went to discount tire paid for VMR 803 19x9.5 et 45 wheels and 265 PSS tires. Those should be here Tuesday or Wednesday, got a $100 visa card on each so an extra $200 in my pocket! Lift is at first lock its the perfect height for sitting in my comfy chair and doing the brakes.
    Senior Member Three Rings phxS4's Avatar
    Oct 09 2013
    Phx/AZ
    These look super nice. When it's brake time for me, I may consider this route. You're going to want to drop your car next! Btw - no tune yet? We need to meet up one of these days so I can check out those rotors in person!
    2013 S4 | Brilliant Black | DSG | Sport Diff | Fine Nappa | Carbon Atlas | B&O | Advanced Key | SC Badges | Roc Euro | AK | AWE catback | H&R OE l v810| GIAC Stage 2+
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    Man.. I absolutely love this setup you have
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Jan 04 2013
    Phoenix, az
    Thanks it's the best $1800 I had spent in a long time. Makes working on my vehicles a heck of a lot easier.
    No tune yet. I have the APR belt and pulley just waiting on tune promo! Heck it's getting so hot I am also watching for cooler upgrade deal as well. APR is doing a change to theirs so curious to see what that is.
    Veteran Member Four Rings isles1's Avatar
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Love that lift! Source?
    Jan 04 2013
    Phoenix, az
    It's a Bendpak me-6xp, I actually got it on amazon direct from them. They have fixed pricing so if they have a sale everyone has the same price. On Amazon I got free shipping and had it shipped to my work. This allowed me to use the forklift there and load it on my trailer so I didn't have to pay for curb service.
    May 13 2011
    2015 BMW F30
    this!
    Lol at small jack being rated at 6k lbs
    love the new rotors
    | Autospeed | JHM | Pure MS
    Jan 14 2009
    pasadena md
    Im not sure what you mean. But i got what the OP original post meant the first time i read it. I guess because i have been looking into lifts for awhile.
    Let me know how you like the setup. I want to get the 2 piece rotors just not sure which ones.
    Jan 04 2013
    Phoenix, az
    will do, at this point I just drove around the block to make sure I had brakes. I am still on the donut spare until the wheels and tires come in on Tuesday or Wednesday.
