Results 1 to 17 of 17
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    Sunroof Question
    Why, when you turn the dial back to open, the roof opens to 3/4? Then when you turn the dial to the spring catch, it goes back the rest of the 1/4. Why not just open it all the way? I did an air test at constant speed, and I can detect no more/less air in either position.
    2011 Audi S4 // P+ // Sport Diff // DSG
    EPL Stage 2 and TCU | AWE Touring Exhaust | 19x10 et42 Forgestar F14s | Ventus V12 255/35/19 | KW Street Comfort Coilovers | EuroCode Rear Sway Bar | EuroCode Trans/Diff Mount Inserts | EuroCode Alu Kreuz Driveline Stabilizer | CR15 Strut Tower Brace | StopTech SS Lines and Fluid | Akebono Euro Pads | Centric High Carbon Discs
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    I can't open mine fully on the highway to annoying. Plus if the sunroof is open and windows are up it makes a really nasty pressurization bass noise when it's fully open.
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Apr 10 2016
    Reading/PA
    From what I read in other threads that discussed this, it is to prevent buffeting in the cabin when the windows are all closed.
    At highway speeds, having it 3/4 open is ok, all the way is annoying.
    2011 S4 P+
    Unitronic Stage 2+ ECU / Stage 2 TCU | JHM 179 Crank Pulley | Vogtland Coilovers | CR-15 | Eurocode Intake Pipe | Drilled Airbox | ECS X-Pipe | ECS Rotors | VMR 710 19x9.5 ET45 | 265/35 Pilot A/S 3
    IG: b8_s4thewin
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    I will echo the others here..... with the windows up, the 3/4 open is perfect. Open the roof fully with the windows up and the wind buffeting is unbearable. The engineers at Audi know what they are doing in this category.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by MVR 155 View Post
    I will add to it. My B5 S4 had no "stop" you just turned it all the way and it went all the way open. There was no catch or stop. But it was annoying to have to figure out where to turn it to to stop the wind noise. Its nice and annoying at the same time. But atleast they took the guess work out of it for you.
    Veteran Member Four Rings doughboy17's Avatar
    Aug 05 2010
    2007 Audi A4 3.2 Quattro; 2021 Mazda CX-5 Turbo Carbon Edition (my wife's vehicle)
    Central IL
    The engineering of these cars amazes me -- sometimes that's a good thing, sometimes it's a bad thing. ;)
    2014 Monsoon Gray S4 Prem+ | S-Tronic w/ EPL tune | LH Magma Nappa leather interior | Carbon Atlas inlays | Sports Diff | Adaptive Damping suspension | 19” peelers | MMI Nav | B&O | EPL Stage 2 via JHM 179mm crank pulley | Resonated AWE Touring w/ 102mm tips | ECS silicone intake tube with aFe filter | RKX tranny mount insert | tints | VAG COM mods via OBDeleven | Autostyle Mats
    Established Member Two Rings 604bking's Avatar
    Feb 26 2015
    This is the case for most cars' sunroof. I believe it's due to what others have said regarding the buffeting noise.
    2014 Audi S4 | Phantom Black | Technik | Sport Diff | Black Optics | Magma Red | Carbon | S-Tronic | RS Grille | Rho Plate | H&R Springs | H&R Spacers | 20x10 Vossen CV3 Matte Graphite....All show, no go
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Quote Originally Posted by 604bking View Post
    My '16 S4 opens all the way when I turn the dial to the open position. Continuing to turn the dial into the spring loaded position does nothing.
    I read online that only the cars with a panoramic roof have the 3/4 open setting.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    My 2015 works differently. You turn dial clockwise to the first detent, sun roof open to 3/4 position. You must turn and HOLD switch further clock wise to fully open . Tilt is open push, and lower tilt is one push. The opening detent is clearly marked on the base of the switch.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    My B6 S4 and A6 2.7t would open all the way. when actuated and with all windows closed there was severe buffeting in the cabin. To combat all the complaints that Audi received about this condition, Audi had the sunroof automatically open to about 3/4 position. The driver could then activate to open 100%. This is the way my 2010/2011/2014 operated. BTW, the same thing happened in both of my wife's Lexus.
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by eightamrock View Post
    To what panoramic roof are you referring?
    Jan 21 2016
    Quote Originally Posted by Dr GP View Post
    My Q series has a panoramic moon roof but the sunroof is the same as my S4. It does do the 3/4 open though.
    Not sure really which one they refer to, but that's what the owners manual says too.
    I think mine needs a reset.
    Jan 21 2016
    Just an update, I am at the dealership now for the 5k service. They said it is in fact broken, they are replacing a part. Ill post the part once I find out, just incase anyone else has this problem.
    cheers.
    Active Member Two Rings boolias's Avatar
    Dec 16 2015
    Santa Cruz, CA
    cheers.
    Hey did you ever find out what the broken part is? My 2016 does the same thing. Opens all the way and the spring-loaded position does nothing.
    Established Member Two Rings jjslegacy's Avatar
    Oct 14 2006
    2015 S4/2013 Q7
    Cleveland
    Quote Originally Posted by boolias View Post
    Same problem here on my 2015 - opens all the way and no need for the spring loaded position
    JJ
    Jan 21 2016
    They didn't get the part yet, apparently it has to be special ordered from Germany. I don't have an invoice or part number yet, but it's some kind of $1500 stepper motor.
    Jan 21 2016
    Finally came to a resolution on this. Apparently for 2016 they changed this. Of course Audi replaced the motor and then decided to check another car. Haha on their dime anyway. So it works as designed.
