Who is running Mercedes GL350 rotors? I thought I saw someone running them instead of the ML55AMG rotors. They're 350mm vs. 345mm on the ML, so I'm wondering what was needed to make these work with the kit. I know the ML rotors are easy peasy and only require removing 1mm from the center bore with a sanding wheel. If it's just as simple on the GL rotors, I may as well go that route.
Thanks.
