Results 1 to 8 of 8
Hybrid View
    Senior Member Two Rings Jmstrag's Avatar
    Aug 15 2010
    Need help with service interval message...
    So I've reset my service due notifications using VAG-com a few times. In the past I've changed the adaptation values individually without issue. This time I used the SRI button as recommended by ross-tech. The issue I'm having is that every time I start/turn off the car.....i get a message stating "service in KM/days". It never did this for the previous resets and I'm finding it a bit annoying.
    I've redone the SRI a few times as well as sniffed around various adaptations to no avail. Does anyone know how to disable this?
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Manual reset channels to 0 in cluster module 17, in order channels 40,41,53,55,2. Each channel new value 0, test and save.
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    It's possible to do it through the actual SRI reset function too... I think that you need to reset it using "#2 mileage based reset (USA)" but the few times I've reset @lambda13's car it's been some trial and error.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Aug 15 2010
    Thanks for the suggestions guys....i tried both methods with no success.
    I did notice that adaption 02. "Service reminder due" Is set to 2. When I set it to 0 test/save it applies but then goes back to 2. No idea what the value 2 stands for as it says (0 = service not due, and 1 = service due). Maybe that's part of the issue?
    Starting to think I might be stuck with this annoying pop up. So strange
    Nov 19 2017
    Serbia
    Quote Originally Posted by Jmstrag View Post
    @Jmstrag I have exactly the same problem.
    DId you or anybody managed to solve this problem?
    I drive Audi A4 B8.5 2013
    Feb 13 2004
    Silicon Valley, CA
    Similar problem with me. Did oil and filters on my car and another car today. Used VagCom to reset the reminder using the "Automatic Service Reminder Interval" reset button, but it did nothing.
    Kevin - Moderator, Audizine
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    I changed my oil today as well. Ive read that carista has this feature on the beta, im still waiting for the app to update
    Sent from my HTC One_M8 using Tapatalk
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jul 08 2015
    Update: carista reps sent me a beta link to version 3.0 and i just used the service interval reset feature.
