Results 1 to 26 of 26
    Mar 29 2014
    Hampshire, UK
    ROC-Euro Install - S7
    Hi Guys,
    Here is a quick set of installation instructions for the ROC-Euro intake for the S7 since the intake does not ship with instructions - this is applicable to the RS7 and S6 models as well.
    As I was moving from an AWE S-Flow Carbon intake, Ive not provided any instructions on removing the standard airbox. Suffice to say, the hardest part (that I recall) was removing the bellow connections to the turbo intakes, as the heat from the turbo units had effectively "welded" the bellow connector to the intake pipes - some gentle persuasion with a flat screwdriver finally got them moving.
    So this is what I started with, and was an easy removal - undo the jubilee clips on the intake pipes and remove the two screws holding the front of the intake box to the air scoop. Unit came out as a single piece, so no need to dismantle.
    This is what I was fitting:
    Once you remove the factory/AWE airbox, you can see the three push-fit mounting points. You completely remove the two mounting points as marked by the arrows. (They are simple push fits - remove the central foam insert, then pinch the tabs to remove the holder)
    You should now have two of these showing:
    Mystery of where the drywall plugs go is solved. The heat deflector plate only fits one way, drop the drywall butterflies into the hole(s) and tighten up.
    Assemble the intake - you may have to play around with the filters and jubilee clip - to get the best position so they are not seen once fitted (I have to adjust my top filter as the silver filter seam is showing)
    From here on in, its pretty obvious what to do next. You may have to adjust the final resting places of both intakes, to ensure your not going to be rubbing against anything. The pipes themselves rest on the heat deflector plate you installed earlier. Larger pipe first, smaller pipe sits over larger.
    Not much clearance here - close to my matrix headlight loom, so will keep an eye on this to check for any chaffing.
    Job Done - Note that I refitted my OEM air intake pipe - If your coming from the stock intake, you will leave this part in place.
    Now, I know a lot of you guys are complaining about slow deliveries, poor comms from John and questionable power gains. My total wait time was about 9 weeks from placing the order to getting the shipping email. (For those of you in the UK, I had to pay customs import duty of £85 on top of the purchase and shipping costs)
    Ive not dynode my S7, and don't intend to. So I will leave you with this comment. The S7 sounds freaking AWSOME with the ROC-E's installed. 110% better than stock, and way, way better than the AWE S-Flow box. If you've ordered, it will be WORTH the wait!
    Cheers,
    JW.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    Awesome write up and now.... Video of sound! Go!
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Thanks for the info and pics.
    +1 to video of said awesome sound!
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Mar 29 2014
    Hampshire, UK
    The problem with trying to get a video/recording of the sound is that you have to be moving/accelerating with the window down in order to capture said sound. Unfortunately I don't have a GOPRO (or equivalent) and all you can hear is wind noise when I try using my phone LoL.
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Really hard to pick the sound up on a phone but this can give you an idea!
    https://www.youtube.com/watch?v=eG010iXUUlA
    https://www.youtube.com/watch?v=bFlY0wm3dJ8
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Mar 29 2014
    Hampshire, UK
    ^^ This ^^
    Thanks Jesse
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by jkwelsh View Post
    ^^ This ^^
    Thanks Jesse
    yeah the wind noise makes it really hard to capture it. Also on that fly by I thought it would be a lot louder but there is road noise with other cars and it didn't really come out how I thought it would.
    Oh yeah don't mind my 3 year old laughing every time he hears the blow off valve.
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by Sd76 View Post
    You want the 3.0 sound since you have the A7?
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Feb 01 2009
    Pa
    Quote Originally Posted by agent47 View Post
    Lol. I want the rs7 sound in my a7! Haha. I just went to depot and put 4 bags of mulch and fert in my trunk and then looked at it from the side.... It looked like it was lowered on coils... Now I want it lowered even more!!!!!
    Feb 01 2009
    Pa
    So what would you go with if you didn't get roc euro? Injen? Another... Looking like the roc euro although the better sounding is still having problems making it to people that ordered....
    Mar 29 2014
    Hampshire, UK
    I had the Injen on my A7 3.0T. Its a good piece of kit, and allows the superchargers to breath easier. If your a fan of hearing your car perform, you wont be disappointed with the Injen intake.
    If the Injen was available for the 4.0TT, I would have likely purchased Injen over the AWE S-Flow.
    Here it is on my A7
    Feb 01 2009
    Pa
    Here it is on my A7
    Looks good does it need a heat sheiks or no bc it's metal? I believe hack devil Had it and thought it was too quiet??? Or maybe it was another brand will look it up.
    Do you have a sound clips of it would love to hear it in an A7 3.0
    Jun 19 2016
    Houston
    Not so sure about the roc intake personally, if you look at where the air is coming in, looks to me like 80%+ of that air is hitting the lower filter and not much at all is reaching the other filter, one of the turbos is getting a workout at least. Just how it looks to me could be wrong though.
    Feb 01 2009
    Pa
    Quote Originally Posted by AS6 View Post
    So you like the Injen setup better and SIUND is decent?
    Mar 29 2014
    Hampshire, UK
    No sound clip, sorry. Suffice to say the supercharger spin up is significantly louder than stock (which I like)
    No need for a heat shield, as the filter end literally sits within the original filter housing, so is being fed cold air from the front scoop.
    Feb 01 2009
    Pa
    Nice maybe I will pick this one up instead of roc euro since delivery is an issue.
    Install pretty easy? I'm NOOOOO mechanic lol!
    Jun 19 2016
    Houston
    I like the USP setup with its larger pipes somewhat "similar" to the Injen I guess, or the Revo, which is basically just a factory RS7 air box. I will be keeping the factory box in my car and just replacing the restrictive filter with a high flow filter.
    I'm sure the roc intake is very good I know a lot of people seem to like it and I'm certainly no expert, everyone has there own preferences.
    Cheers
    Mar 11 2014
    Dallas/TX
    Injen might not fit the 2016+ 3.0T models unless you want to remove the stock airbox completely.
    Feb 01 2009
    Pa
    No... I'm a minimalist lol. Least amount of work for me :)
    Stayed tuned... Ordered new wheels finally and will bE moving on to coils right after I get them. Will post pics after
    Well if roc euro gets caught up with delivery maybe I will do that one. Will see
    Apr 06 2016
    so cal
    The thing about forced induction is it doesn't matter where the air around the filters wants to hit or be, it's going in both of them equally since each one feeds a turbo. This is also why worrying incessantly about how cold that side of the intake process is, is sort of misplaced effort. There's a temp delta going through the turbos and a much more important delta based on how effective your intercooling is.
    If you're supremely worried, go meth. It doesn't seem to be much of an issue and since the exhaust side--the hot side--of the engine is down the middle, the sides don't get that hot
    Slovenian tin exhaust, some worthless intake that isn't the SRM yet, cete valve controller because the akra one doesn't work properly on c7.5, apr stage 1 ecu/tcu, 5(five) bbs ci-r's because my car loves potholes, Eurocode sways/links, Eurocode alu-kreuz, and an undying love of hard parking
    Jul 01 2016
    Orange County, CA
    Thanks for the write-up. I installed mine on my S6 this afternoon and the guide was very helpful. For those needing a write-up on how to remove the stock box, take a look at the write-up on the AWE intake, as theirs includes stock box removal, however you only need to do steps 6 and 7 (after removing the engine cover) as you are leaving the inlet scoop intact.
    As far as level of difficulty, you don't need to be a mechanic, but just have common sense and use the guides. It took me 45 minutes start to finish, and I was going very slowly and carefully. If I had to do it again, I would say 20 minutes tops.
    2016 S6 Premium Plus Dakota Grey/Arris Red - Sport, Bose, LED, Black Optic, APR Stage 1 ECU & TCU upgrade, Roc-Euro intake
    2016 SQ5 Premium Plus
    Apr 06 2016
    so cal
    sounds decent on the iphone6+. I'd love to get it on a zoom mic or something similar, but I can't see spending 1~200 to make car videos 3 times :)
    Sep 28 2009
    suburb
    if one wants to remove the heat deflector, how is it removed with those toggle bolts?
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Veteran Member Four Rings OlyS6's Avatar
    Nov 22 2016
    Olympia, WA
    I just did this and it was a PITA I let the toggles fall in to the frame rail. You should notice a good size rubber plug on the outer aspect of the frame rail- pull that out and you can dish out the toggles with either a magnetic stick or a coat hangar, which I ultimately used to fish them out. There might be a smarter/easier way, but it worked
    2016 S6, mythos black, RS7 turbos, MRC inlets |Akrapovic exhaust| AMS downpipes and intercooler |Eventuri intake| Loba HPFPs |Tial wastegates| Eurocode sways, end-links, and AK | Audi CCB| HRE P103, 20x10 | RS6 grille| Neidfaktor CF mirrors, diffuser, and steering wheel| Blackvue dashcams| Escort Max CI 360 | RS6 LED headlights, OEM Euro tails |Sound: Navtv Zen-v preamp, Helix DSP Ultra, JL HD900/5 driving JL10W3 sub and Hybrid Audio speakers.
    Sep 28 2009
    suburb
    well I just installed this. too loud for my taste. I'm taking it back off and will sell it. the BOV sound is awesome, I just want it quieter. I'm gonna drill some holes in my stock airbox since it's out.
    And my butt dyno did feel like car is faster!
    Audi SQ7
    Audi B8 S5 (gone)
    Apr 22 2015
    S7 Q7 Ram 2500 Cummins
    North Texas
    I just used this how to. took about 20 - 30 minutes.
    thanks for the write up.
