Results 1 to 2 of 2
    Apr 22 2014
    Bath, UK
    EVAP Emission Control System
    Any ideas on things to check for this error code?
    Car flashed up with the warning triangle, but kept driving fine.
    3.0TFSI with Stage 2 Pulley and Map.
    Code:
                    Address 01: Engine       Labels: 06E-907-551-CGW.clb
    Control Module Part Number: 4G0 907 551 F    HW: 4H0 907 551
      Component and/or Version: 3.0l V6 TFSIH07 0005
               Software Coding: 12250034052701020000
                Work Shop Code: WSC 02311 785 00200
                  ASAM Dataset: EV_ECM30TFS0214G0907551F 001005 (AU57)
                           ROD: EV_ECM30TFS0214G0907551F.rod
                          VCID: 2C57F9C547FE635EF2-8078
    1 Fault Found:
    19581 - EVAP Emission Control Sys
              P0441 00 [101] - Incorrect Flow
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 60472 km
                        Date: 2016.05.26
                        Time: 19:59:50
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    My guess is gas caped wasn't secured properley!
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
