Results 1 to 40 of 52
    Stage 2 Banner Advertiser Four Rings Josh/AWE's Avatar
    Feb 08 2012
    Horsham, PA
    AWE Tuning: Introducing the SwitchPath™ Remote for 8V S3. Available now.
    Instant satisfaction at the press of a button. Presenting the AWE Tuning SwitchPath™ Remote:
    • Open and close exhaust valves with the push of a button from inside the cabin at any time
    • Works with stock system, or AWE Tuning SwitchPath™ Exhaust
    • Comes as a set of two remotes with wiring harness, control box and mounting hardware
    • Compact design perfect for a keychain or cup holder
    • From quiet to aggressive with the tap of a button
    • No Check Engine Light- Guaranteed
    What it does:
    The AWE Tuning SwitchPath™ Remote and accompanying control box overrides the factory valving to allow the exhaust valves, whether it be on the AWE Tuning SwitchPath™ Exhaust or the stock exhaust, to be opened or closed manually via the SwitchPath™ Remote.
    How to operate:
    With the AWE Tuning SwitchPath™ Controller installed, the exhaust valves can be opened by pressing the “On” button found on the left side of the SwitchPath™ Remote. To close the exhaust valves simply press the “Off” button on the right side of the remote.
    What’s in the box:
    The AWE Tuning SwitchPath™ Remote comes complete as a kit with two remotes, two mounting brackets, the SwitchPath™ Controller, one AWE Tuning Valve Simulator, and easy to follow instructions.
    Claim your SwitchPath™ Remote right this way.
    Questions? Hit me here or email me directly.
    Performance Specialist
    AWE-Tuning.com > 1.888.565.2257
    my email > facebook > twitter > instagram > youtube
    Jan 12 2016
    Los Angeles, California
    Will the installation and use of this product throw any codes in the ECU?
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    Jan 15 2010
    Santa Barbara, CA
    Very nice. Second the above question - would love to get this at least for my stock exhaust to start.
    Feb 08 2012
    Horsham, PA
    Quote Originally Posted by KevinM. View Post
    Quote Originally Posted by forbiddenbeat View Post
    It will not throw a CEL, gentlemen. The kit includes a valve simulator. For whatever reason if this simulator wasn't installed - there would be a 'soft code' per se, but never a CEL.
    Jan 12 2016
    Quote Originally Posted by Josh/AWE View Post
    Awesome, definitely buying this now
    Feb 08 2012
    Horsham, PA
    Awesome. Hit me if you have anymore questions!
    Jan 12 2016
    Purchased last night
    One more question, is there any way to make open valves the default setting? I assume not, but that would be awesome because I want it open 90% of the time, but that 10% I want to be able to close it easily instead of having to get under the car and re-connecting the wires.
    Jan 15 2010
    Santa Barbara, CA
    Wait, isn't the entire purpose of this that you can close and open the valves at will?
    On that topic, does "off" just meant stock mode? I.e. they still open, but only in certain circumstances?
    Jan 12 2016
    If I am driving and I turn the 'sound' on, and then park, it goes back to off, I'd like it to stay on.
    In the off position they are always closed and never open, in the on position they are always open and never closed
    Feb 08 2012
    Horsham, PA
    Yep!
    This is correct. The SwitchPath™ Controller overrides factory settings.
    So since this overrides the aforementioned settings -- your valves will be closed upon startup unless you turned off your vehicle with the valves open and started it back up within ~45 min - an hour. Once the car is stationary and powered down for longer than ~45 min - an hour, the valves will close.
    Hope that makes sense!
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Absolutely LOVE the AWE Track catback on my S3, fantastic sound and quality
    May 21 2015
    Pacific NW
    Did you add a downpipe to the catback or remain oem? I'm thinking about getting the track catback as I already have their resonated dp but I'm curious if it will produce any drone or humming accelerating through the 2500-3500 rpm range. Right now I get that with the Audi resonator delete and it's annoying.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2008 BMW 535xi (sold)
    2006 A3 2.0T (sold)
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Quote Originally Posted by Nathing32 View Post
    I had a catless and resonatorless downpipe, I went back to OEM as that was far too much for me as a DD. I'd highly recommend pairing their catback with one of their downpipes (with the resonator) as this would provide optimal sound without ruining your car IMO. That was the mistake I learned the hard way unfortunately.
    May 21 2015
    Pacific NW
    Thanks man! That's about what I was hoping to hear. Sorry about having to learn that lesson the hard way but others can benefit from it at least. I'm sure the reciprocal is going to happen for you in the future.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2006 A3 2.0T (sold)
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    You're welcome, happy to help others and weigh in with my personal experience. I'd like to save anyone from going through my experience as it was a bit of a headache (literally). After that, I'd recommend a HFC and resonated downpipe setup if you're going aftermarket.
    I came from 2.7T's and running catless downpipes into an AWE Twin1 catback, which are "loud," yet AMAZING sounding, but very DDable IMO; so naturally I thought I'd be fine with a catless/resonatorless downpipe on a 4 cylinder. I think with our cars and the EA888 motor, its the acoustics produced by the exhaust manifold being integrated into the head of the car causing such a loud/drony and unpleasant noise when you completely remove the cat and resonator. Ultimately this is just me speculating, but I do believe that is what creates the awful cabin noise.
    Nov 29 2005
    PHL
    Josh are these in stock in WG now? Can I pick up Thursday?
    Feb 08 2012
    Horsham, PA
    Quote Originally Posted by RyanS3 View Post
    WG... you mean Horsham? :)
    Answering your PM now.
    Nov 29 2005
    PHL
    picked it up from John this week.
    installed today.
    thanks for providing this part!
    2015 Audi S3 build thread just sold it!
    Cars & Coffee on Flickr
    Need to start a new thread for the new car, TTRS mk3
    Feb 08 2012
    Horsham, PA
    installed today.
    Enjoy it!
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    Enjoy it!
    Josh, is it possible to have 3 modes
    stock
    open
    closed
    if not is it possible to have
    open
    stock
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Feb 08 2012
    Horsham, PA
    Quote Originally Posted by saxon View Post
    stock
    open
    closed
    open
    stock
    Not possible with the current configuration, Sax.
    We could investigate that in the future, though.
    Oct 16 2012
    pa
    that would be great, i personally dont plan on doing an exhaust so im not needing to quiet it down, i just want the option to make it louder or have it stock
    thanks!
    Feb 08 2012
    Horsham, PA
    thanks!
    Duly noted, muchacho!
    Dec 11 2015
    Syracuse,NY
    need one for my A3....:(
    2015 black A3 Premium---APR stage 2+DSG tune, APR carbon fiber intake, Bilstein B16 PSS10. USP downpipe, Milltek non-resonated catback. emmanuele design carbon fiber rear spoiler
    Feb 08 2012
    Horsham, PA
    Lots of SwitchPath™ Remotes have been flying off the production benches and onto FedEx trucks. I hope everyone is having fun with them!
    Jan 12 2016
    Got mine last week, and installed in 20 minutes, with most of the time spent on cleaning up the wiring.
    It works very well, does everything you expect it to. Awesome product.
    Great work AWE!
    Feb 08 2012
    Horsham, PA
    Good deal, Kev
    Feb 08 2012
    Horsham, PA
    In control with @teddy_gram1936 and the AWE Tuning SwitchPath™ Remote!
    Active Member One Ring Q-tip's Avatar
    Jul 06 2016
    Japan
    I received it today.
    And I surprised when I open the package
    Is this normal??
    Feb 08 2012
    Horsham, PA
    Quote Originally Posted by Q-tip View Post
    Is this normal??
    Everything looks normal to me!
    Registered User Four Rings XLR8 Craig's Avatar
    Feb 14 2014
    Audi's
    Branford, CT
    Okay I must say, playing with this thing on a Golf R is quite addicting....
    This Blow Pop is pretty tasty too.. just wish the gum didn't turn to rubber cement after 2 minutes.
    Feb 08 2012
    Horsham, PA
    Push-button mood control with the SwitchPath™ Remote!
    Dec 11 2015
    Syracuse,NY
    Does this fit 8v A3 2.0T?
    Established Member Two Rings ahfunaki's Avatar
    May 23 2016
    Northeast Ohio
    Any sound clips with the stock exhaust?
    tapatalked
    2016 S3 Premium Plus | Glacier White Metallic Exterior | Black / Titanium Gray Interior | Black Optic | Technology | LED | B&O
    Emmanuele Design Springs | 15mm Spacers Front & Rear | aFe Magnum FORCE Stage-2 Pro 5R Intake | OEM Resonator Delete | AWE SwitchPath Exhaust Remote
    Feb 08 2012
    Horsham, PA
    Quote Originally Posted by ahfunaki View Post
    Unfortunately I do not have the aforementioned.
    May 23 2016
    Northeast Ohio
    Hmm, send me one and I'll make a nice quality video for you! Haha...
    May 21 2015
    Pacific NW
    Anyone have a problem with the valves opening and closing constantly after pressing the "On" button? Mine started doing this recently.
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2006 A3 2.0T (sold)
    Feb 08 2012
    Horsham, PA
    N,
    Please fill this out ASAP!
    Established Member Two Rings rsquattro's Avatar
    Sep 18 2006
    US of A
    I've had a problem with valves failing...twice in two years. Sounds like a Civic R with a bad exhaust. Makes me not want to drive the car, and the lead time on valve replacement is surprisingly long, while the car is parked at the shop and I had to miss two track days and out of pocket travel expenses back and forth...
    '15 S3 P+ Mythos
    May 21 2015
    Pacific NW
    Josh - I bought this off another Audizine member a few months ago but it only started acting up recently. I filled out the form just now. Thanks!
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2006 A3 2.0T (sold)
