Results 1 to 3 of 3
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    EVAP Emissions Control?
    My RS4 is now throwing a check engine light for:
    1109 1 P0455 EVAP Emissions Contr. Sys (Gross Leak) Leak Detected (Upper limit exceeded static)
    1089 2 P0441 EVAP Emissions Contr. Sys. Incorrect Purge Flow (Lower limit not reached static)
    Any help would be greatly appreciated, and yes my gas cap is securely fastened.
    "Brake last, finish first."
    May 06 2014
    2015 Ford Mustang Ecoboost, 2011 Nissan Armada SL, 2015 Buick LaCrosse E-assist
    Beloit, Wisconsin
    Bad gas cap?
    Otherwise, one of the lines that run between the tank and the pump might have rotted.
    Oct 14 2009
    AZ/NY
    I might buy a new gas cap. However, I do not think thats the issue. Anyone else have any input. Thank you.
