Results 1 to 6 of 6
    Apr 04 2015
    United States
    Squeak in Rear suspension
    I've done a search to no avail.
    slow moving high frequency articulation in the rear suspension is giving me some pretty good squeaking/ creaking. Example: turning into my driveway that is a slight grade.
    I have H&R coilovers, front adjustable control arms, but no other suspension mods. Before I go diving into it this weekend, I was wondering if anyone has some thoughts, or has encountered the same.
    2012 Audi S4: 74,000 miles
    thanks in advance.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    How old are your coilovers and does the squeak happen only over bumps?
    Apr 04 2015
    United States
    Quote Originally Posted by xalents23 View Post
    The coilovers are maybe a year old, and yes, only over slow articulating bumps...... Actually... I will have to pay attention to that now.. now you have me wondering if I hear it during slow speed turns too. I'll get back to you on that.
    Oct 26 2011
    CA
    Well, I had H&R coilovers and my rear squeaked like a door hinge over bumps. It was the rear strut bushing which collapsed. Had to get the bushing from an H&R dealer. Don't know if yours is going to be the same issue but, worth checking it out. This was on a B5 S4.
    Apr 04 2015
    United States
    Thank you! I will definitely check into that!
    Apr 04 2015
    United States
    update: it wasn't the rear, it was the front adjustable control arms. The one boot came off and the joint was dry. Re-greased it, reconnected the boot and I'm back to no more creak...
