Results 1 to 21 of 21
    Active Member Two Rings audialucks5's Avatar
    May 26 2016
    1973 mach one, 351 cleveland
    Ohio
    B5 S4 restore, NEED HELP!
    recently purchased a 2000 S4, 2.7L bi-turbo. currently drive a 98' A4 quattro 2.8L and know my way around it decently but have noticed that the parts i need for the S4 are not the same as my A4. was wondering if you guys could help me out with telling me what parts i can nab off of an A4 quattro and what parts i will have to buy off an S4. so far i know that it will need a core support, radiator, ac condenser and the fan that sits on top of the condenser as well. Is the core support in an S4 the same as the V6 model b5 A4's? will an A4 radiator work on the S4? any help is appreciated. also, how do i attach an image? first time on the forum.
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    A good friend just tried a v6 a4 core support and said it didn't fit right. Surely someone here can confirm or deny.
    I use photobucket to link pictures
    2002 Pearl/onyx S4 Avant
    May 26 2016
    Ohio
    all the parts needed for the S4 are outrageous, any idea where i can find those parts cheap?
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by 88ninety9 View Post
    Ummm....no. All B5 V6 core supports are the same.
    OP, you can pretty much grab all the body panels, front/rear control arms, front/rear subframes etc, from a 2.8 A4. Pretty much the same on the surface and most of the underside.
    EDIT: You can use most of that stuff listed from a 2.8 A4. The rad will not work, because reasons
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    May 26 2016
    Ohio
    thanks! what about the radiator off a V6 automatic? the S4 is automatic as well. looking online the only S4 radiators i could find were 350-400 bucks
    Nov 02 2012
    Indianapolis, in
    Quote Originally Posted by Bordom View Post
    Like I said, someone here can confirm or deny.
    I was under the understanding to use an a4 core support you'd have to trim for the radiator, parts of the sides, and use the a4 snub mount cage.
    Soooo, no. Not the same
    Dec 10 2013
    Quote Originally Posted by audialucks5 View Post
    No idea. Best to find a good used one. Look on ECS and compare the auto A4 and S4 rads.
    Maybe for a 1.8T core support as that shit is all different. As for the snub cages, the 2.8 and 2.7T snub cages are the same. The only different one is the 1.8T
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Four Rings Cgoon009's Avatar
    Mar 02 2013
    I have a garage? Do tell...
    DC
    Ok I can help here.
    So the core support from a 2.8 B5 will not work on the 2.7tt - Reason, intercoolors. I have both, so I can compare them for you when I get a minute.
    If you need a front end for the S4, you will have to buy the core, rad, aux fan and inter-cooler brackets. Reuse the S4 wire harness to keep things simple. The headlights and hood latch should be the same. So you can reuse those. Also the bumper shocks mounts are different, but the side hooks are the same.
    Not sure if the part will fit? Use ECS or similar sites to find part numbers and compare.
    There are a lot of things that can be swapped, but the front end is not one of them.
    Eurosport Tuning at it's Finest
    May 26 2016
    Ohio
    the picture for the radiators is the exact same for both the A4 and the S4, difference is price, the A4 radiator being around 200 and the S4 being almost 400. doesnt make much sense...
    May 26 2016
    Ohio
    looks like ill be dumping some big bucks into it then. there are very very few S4's in ohio so finding used parts is next to impossible.
    Nov 02 2012
    Indianapolis, in
    IIRC, the a4 cage mounts with only 3 bolts. There are multiple threads on the trimming needed to use the v6 a4 core support
    Looks as if cgoon is going to clear things up
    Dec 10 2013
    Yeah, he cleared it up. I was pretty confident everything was the same lol
    IG: 24_et
    Sold:
    RIP:
    Feb 27 2011
    Winnipeg
    core supports are different for sure, you can make a 2.8 radiator fit, I had to since an s4 rad is crazy expensive compared to an a4 one, you just have to trim a piece of the rubber that the pegs of the rad fit in in the core support. pretty sure the condenser is the same as an s4 as well, and you don't technically need the pusher fan in front of the condenser either, Canadian spec s4s never came with them.
    Mar 02 2013
    DC
    Quote Originally Posted by seanf86 View Post
    Can you elaborate on the cutting to fit? You had to modify the footing on the core support or something on the radiator itself? It would be nice to not have to shell out so much for a new one.
    May 26 2016
    Ohio
    Agreed. Anything for the S4 is way overpriced. Just ordered a radiator that the manufacturer said would fit, I will let everyone know if it does
    Feb 27 2011
    Winnipeg
    if its from rock auto or a spectra premium it won't, its actually for a 2.7t a6
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by Cgoon009 View Post
    the pegs on the 2.8 radiator are about 5/8 an inch closer together than the s4 rad so they don't fit in the round rubber pieces in the core support, I cut 3/8" into the side on each of the rubber pieces so that the radiator fit in there. Heres a pic of what I did, more cutting than you have room in the rubber may be necessary so I just ground one or both sides of the core support with a dremel sanding drum too.
    May 26 2016
    Ohio
    I'm a real amateur when it comes to things like this, my first car was a Dodge Ram and that's where I learned how to work on cars, extremely different from an Audi obviously. Here is what I bought: http://m.ebay.com/itm/New-Radiator-F...=1409991859006 Will it fit?
    May 26 2016
    Ohio
    My lack of experience is comical, but that's why I turned to this forum. My first time working on anything remotely serious on an Audi. All I've had to do to my daily is replace some cv shafts and the rest has been paint and sound system.
    Nov 02 2012
    Indianapolis, in
    Best way to learn is to do alot of reading through out this forum. There's an abundance of information here.
    Senior Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    I don't know if you are near cleveland area but I am in Buffalo, NY and have an automatic and manual s4 parts cars if you still need those front end parts. Might be meeting a fellow Ohio member shortly in Erie, PA pretty soon too. PM me if you still need parts
    Silvia = 02 s4 stageIII
