hrm, it's showing flow and pressure problems but it's not showing DTCs for the purge valve, leak detection pump, etc. assuming there's not a puddle of gasoline under your car from a cracked fuel line or tank, it could be a loose vacuum connector or cracked line (both of which can happen during a service).
what did they do to your car? i'm not sure about RS4s, but on S4s the evap system is mostly a mass of hoses and components between the airbox and the cabin air intake; there is also the LDP in the rear driver's side wheel well. any work around there could have done something. the fuel lines run from the tank to under the passenger side and then up into the engine bay. those are hard to disturb, unless the car is improperly jacked up (unlikely at a dealer - mmm, RS4 jack pads - but not impossible).
- emilio
