Results 1 to 22 of 22
    Deactivated Three Rings
    Apr 28 2012
    ny
    Dead Car need help
    I put gas treatment in my car when my tank was 3/4 full. I then read the directions that said to put the treatment in my tank when it was less than a quarter full. My car started chugging immediately and was giving me issues when starting. My car now wont start at all and isnt getting any gas. My rpms when I try to crank over wont even go passed the first line. Does anyone have any idea what I need to do to fix it? I towed it to Audi of Manhattan and they want $215 just to diagnose it and that comes in addition to any repair costs. HELP!
    Veteran Member Three Rings piotrowr's Avatar
    Jul 18 2008
    Scottsdale
    Let us know what they find. I have never used gas treatment in my life.
    2010 A4 Avant Prestige - 19" Sport Package, Quartz Gray Metallic
    Jun 08 2008
    Calgary AB Canada
    Why did you put gas treatment in the car in the first place? Was it running rough? How do you know it's not getting gas? Have you tried to see if there's pressure at the fuel rail?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Four Rings poweredbyaudi7's Avatar
    Dec 19 2006
    996TT
    San Antonio, TX
    What was the treatment you used?
    '14 A4 Q6MT / APR KO4 / AWE / HRE / H&R / 034 Motorsports / P3cars / JHM
    Dec 01 2011
    yea what did you use? i've not used actual gas treatment before but i've used Berryman B12 cleaner, which you pour into the gas tank, filled when it was low then filled up gas, etc. as it instructs. but that was a cleaner and not for the actual gas so im not sure if there's a difference. but i've used that twice and have had no issues.
    maybe whatever you poured in didn't mix in all the way and the fuel pump is currently pumping just that and not getting the power. maybe stick something in the tank and stir? lol. or did you try to fill some more gas into it from a container and then try it again.
    IG @theshawon
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    If you put the treatment into the tank and you have 75% full of gas, then it really would dilute the treatment.
    What you can do is hook the hose from the fuel line to the High Pressure Fuel Pump, send that hose to a tank/bucket and hot wire the fuel pump relay to stay running. This will basically drain the tank.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Quote Originally Posted by onceover View Post
    This. Check pressure at fuel rail would be my first thought.
    2016 S3
    Instagram- @Thisisastickup
    Apr 28 2012
    ny
    How do you check pressure at the fuel rail?
    - - - Updated - - -
    Quote Originally Posted by Allowencer View Post
    I'm not even going to pretend to know how to do this...
    Oct 27 2010
    Norwood, MA.
    You need a fuel pressure test gauge. There is a shrader valve on the rail that this connects to.
    2016 S3
    Apr 28 2012
    ny
    Quote Originally Posted by poweredbyaudi7 View Post
    The basic autozone gas treatment.
    Jun 26 2009
    Bremerton WA
    I would think the treatment would also be so dilute it shouldn't have much if any effect. Its at the dealership now so not much you can do. I suspect they would first run diagnostic scan for codes. Verify the evap system and fuel pumps are working. Drain fuel and possible charge for a disposal fee. Refuel and see if corrects issue. They may want to charge for a new fuel filter (which is in the gas tank attached to the pump). Did a check engine illuminate? Was the gas cap off with the engine running by chance?
    VMR 710's, APR software, Eurocode HFC
    Apr 28 2012
    ny
    Quote Originally Posted by van462 View Post
    I picked it up from the dealer. They wanted $215 to diagnose and that would be in addition to any repair costs. Audis of Manhattan sucks!!! I called AUDI of Brooklyn who said they would charge $140 and the charge would come off of any repairs I did with them. I'm trying to see if I can fix it before bringing it to them tomorrow. I may have to have it towed tonight.
    Jun 12 2013
    Quote Originally Posted by b6Hate4 View Post
    You gotta have a high FP PSI gauge as the rail is under a very HIGH PSI pressure as the HPFP supplies it.
    Build Thread
    Apr 28 2012
    ny
    So we pulled the fuel line from the engine and fuel came rushing out while the car was off. Doesnt seem to be a fuel issue. Audi is saying my timing was off on my car and my valve is hitting my piston and he needs to open up the entire engine. Not sure what I believe at this point. I do here clicking inside the engine itself which leads me to believe he may be right but he is asking $4k to fix it. 10hrs $145/hr. Does anyone know who can do this cheaper in the brooklyn area?
    Jun 12 2013
    Wow, another timing tensioner. Man, that's quite rare that you put additive in and then the car won't start. Check out the threads I have, you'll learn all about it. It is not a cheap fix at all. I'm at close to $2,500 in necessary parts alone to get my engine back up and running; I'm doing the repair myself.
    Build Thread
    Oct 27 2010
    Norwood, MA.
    D'oh. That slipped my mind at the time.
    2016 S3
    Jun 12 2013
    It does to me too; especially if you're more familiar with non-direct injected engines.
    Build Thread
    May 02 2011
    '15 A6 3.0t, '14 GMC Denali Duramax, '12 F150 EcoBeast
    Casper, Wyoming
    Quote Originally Posted by Jerritt View Post
    To be honest a timing tensioner / timing chain failure was my very first thought after I read your first post. The way it failed for you is classic and it's exactly how it failed for me. Honestly If you've got someone willing to fix it for 4K you're not doing bad as once the timing assembly fails it's a real job to get everything fixed up again.
    Apr 28 2012
    ny
    What parts did you need?
    May 02 2011
    Casper, Wyoming
    Here is his thread where's he's working on this: http://www.audizine.com/forum/showth...-and-front-end
    You have to understand that this is heavy mechanical work. You will at the very least be taking the top end of your motor apart. If you've never seen pistons in their natural habitat before then then doing this probably isn't for you.
    Apr 28 2012
    ny
    You can remove the top timing cover without taking off the front end of the car correct? is it just the 5 bolts?
    Can I check the pressure on the fuel line even if the car is dead?
    Jun 12 2013
    Correct on the upper timing cover.
    Yes; you need a high pressure gauge though. When you open the drivers door, you can hear the fuel pump prime. Also, when you just turn the ignition 'on' (not start the car), that will also prime the fuel system. You can hear a faint whine coming from the trunk area (gas tank).
    Build Thread
