Results 1 to 7 of 7
    Established Member Two Rings rtk8892's Avatar
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Options for water pump?
    Hello, so I'm replacing a bunch of stuff on my b6 s4, the water pump being one of them. I ordered one off of ecs on Sunday last week, it's oem and cost me about 407 bucks
    https://www.ecstuning.com/ES284732/
    Anyhow I needed it by Saturday so I could finish my car this weekend and the order keeps getting pushed back. Autozone has a duralast water pump for 130 bucks and I could pick it up tomorrow. I am wondering if going with the autozone pump is a bad choice and I should wait it out for the ecs pump, or if the duralast pump would be just as good of a choice. Here's the link for the duralast pump...
    http://m.autozone.com/cooling-heating-and-climate-control/water-pump/duralast-new-water-pump/audi/s4-quattro/2004/8-cylinders-4-2l-sfi-dohc/184515_269948_0/?location=
    Any insight would be helpful, thanks!
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    No one?
    Jan 09 2013
    ___
    Relax, man. It's only been two hours since you posted. This place doesn't exactly have population of reddit.
    Just so you know, the part you linked is only the pump, not the full thermostat/pump housing. You're going to have to tear your pump/thermostat apart and rebuild it if you go that route, which means you're also going to need the gaskets. They're not expensive, but it's another part you'll need. Look on ebay or the classifieds here. I just bought the full pump/thermostat used for $220.
    Deactivated Four Rings
    Jun 23 2011
    Contact a local Import parts place or a place that has access to WorldPac.
    Mar 18 2015
    2006 Acura TL 3.2
    GA
    Which one? The duralast? The ecs one is the full thing right? The pump and thermostat?
    Veteran Member Three Rings jmcS4's Avatar
    Nov 16 2013
    q7 tdi+, b5 s4, r56 mcs
    Lower NH
    I just picked up a Uro water pump. seems legit, haven't installed it yet though
    >04' S4, Nitrous
    >01.5' S4 dps, tune
    >12' Q7 TDI S-Line Plus
    >R56 Mini S w/jcw aero kit
    Jan 09 2013
    ___
    Quote Originally Posted by rtk8892 View Post
    Yes, the ECS is the full unit. You can find used ones for about 1/2 of that. Mine was working fine, but the only reason why I replaced it is because it cracked.
