Results 1 to 20 of 20
    Active Member Two Rings freire1's Avatar
    May 06 2015
    United States
    Vibration at 60-70 mph after new Toyo Proxes 4 Plus/Rotiform IND-T 19" wheels install
    Anyone have any ideas on how to go about fixing this issue. I bought the wheel/tire package of CarID and had it balanced twice now. Once a regular balance and the second time a roadforce test, and nothing off. Took it to a mechanic but they can't get the car to highway speed, but inspected the car and saw nothing wrong. Took it to Audi and they said maybe the tire pressure was too high, and it was 38psi, which is actually supposed to be 36 front 33 rear for the A3 8V. Not sure if getting an alignment will help anything, but before when I had my winter set 18 inch Audi wheels it did not do that. Any ideas?
    May 21 2015
    Pacific NW
    Bent summer wheel perhaps? Have you ever hit any curbs or deep potholes that could have bent the rim slightly?
    2015 S3
    2015 A6 3.0T
    2004 Allroad 2.7T
    2004 Lexus GX470
    2008 BMW 535xi (sold)
    2006 A3 2.0T (sold)
    Veteran Member Four Rings aaronz's Avatar
    Jun 10 2008
    Spiders
    Chicago And NJ
    Warped rotor
    2016 TTS Launch Edition
    SOLD!!! 2013 S4 DSG Build Thread
    VAG-COM equipped if you need help
    Feb 28 2012
    2016 Porsche GT3 RS
    Marin, CA
    Are you running spacers?
    Mar 14 2016
    Cincinnati, OH
    I've had a similar issue after adding 10/15mm spacers and installing sport springs. ECS sent me a replacement set of spacers as they assumed they were bad, just like I did. New spacers did not help. I've had the car aligned, OEM wheels and tires balanced twice (road force), and installed two sets of new spacers. Still get a slight vibration around 65-70mph. Dealer said they couldn't do anything because of spacers/springs. I've learned to drive at 75-85mph now because I like how the car sits and don't plan to go back to stock.
    Nov 13 2009
    the OC, SOCAL
    if you have anything added to the wheels such as spacers or anything non stock, remove them and drive the car close to stock as possible.
    so, to test if one of the rims or tires is the culprit you need to do is swap the rims around. the technique requires the air is the same in all four tires before do the swap. then swap only one rim at a time.
    example, move the front passenger rim to the rear. leave the drivers side alone. drive the car for a day or two.
    nothing changes.
    leave that set alone.
    move the drivers side to rear.
    drive for a day or two.
    if it stops then you found the rim or tire that was bad
    if there is less issue then more than one rim or tire is bad.
    vibrations are usually felt more with bad front wheels. you will feel very little to nothing if the back wheels are off. therefore, your testing the fronts, but do one at a time.
    bad tires alone can also cause vibrations but usually its rims. a slight bent to rims can cause vibrations at certain speeds.
    May 06 2015
    United States
    Thanks guys. No spacers. Rims and tires are brand new. Did not hit any potholes. But the set came tire and wheel mounted I can't really tell if it is damage but I highly think it is.
    May 06 2015
    United States
    Vibrations do seem to be coming from the front mostly. What is also weird is that it goes away or not as bad after a while of driving at that speed so idk if it's surface too. I'll try to swap each tire like you said.
    Established Member Two Rings Z32drifter's Avatar
    Mar 04 2016
    94 300zx weekend/track toy
    Orlando. Fl
    Are the wheels made for the 57.1 hub or are you using hub centric rings? You might want to try a different set if you're running hub rings.
    Apr 07 2012
    Oregon
    Quote Originally Posted by freire1 View Post
    Is this something that is only in the first couple minutes of driving then?
    May 06 2015
    United States
    It's a 66.5mm hub but I believe it came with Hub rings
    May 06 2015
    United States
    No only when I hit between 60-70 and stay there but for some reason it feels like it goes away after a while at being at that speed
    May 06 2015
    United States
    Any suggestions on hub centric rings? ECS?
    Mar 04 2016
    Orlando. Fl
    I picked up my last set on Amazon. I prefer the metal hub rings. As long as they fit tight to the wheel and hub they should do the job. If they seem to smooth out as you drive, it could be flat spots. I had a previous set of tires that had a vibration every morning, cooler temps made it worse. About half way through my commute they would smooth out.
    Nov 13 2009
    the OC, SOCAL
    wait... so you dont have hub centric rings?
    May 06 2015
    United States
    No I do have them for sure. I'm going to try the aluminum ones from the ECS website
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    my guess is the rings aren't up to par
    Apr 10 2014
    HK
    I had an old B5 S4, took it for a set of new set of rubber on OZ ultraleggaras, when I got the car back I found out the tyre shop had poked the hub rings out when balancing and didn't bother putting them back in.
    The car vibrated like Elvis on speed, when I got home I took the wheels off myself and that's how I found out. They had to give me a brand new set of OZ alloy hubcentrics, cause the mech had lost my old ones.
    Very wary of spacers and hubcentrics now.
    May 06 2015
    United States
    Had a bent rim and two tires so didn't have a chance to place new hub rings. But got everything fixed yesterday and no more vibrations after installing the aluminum hub rings I got from ECS . They fit super snug so no movement inside the rim. Thank you for the help!
    May 06 2015
    United States
    *flat tires
