Results 1 to 6 of 6
    Jun 15 2010
    Chicago
    Anyone know where the A/C evaporator drain is located?
    My A/C has bad smell to it when first turned on. Going to replace the cabin filter but also going to run some A/C evaporator cleaner too. Does anyone know where the evaporator drain plug/hose is located?
    2010 Audi S4 GIAC Stage 2 | 2007 Lexus IS350 Supercharged
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Quote Originally Posted by chi123 View Post
    It should be somewhere on the pass side. Either coming out under the car or in the rain tray. Just run your a/c for a bit on high and look for the water drip.
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    Somewhere near the exhaust manifold.
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    You ever find a definitive answer to this? If not I will try just running the A/C for a while and following the drip. Bought some
    einszett klima-cleaner and want to get rid of this A/C funk but need to figure out where to spray it lol
    Sent from my SM-G935V using Tapatalk
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | Jokerz Ported SC| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jan 10 2016
    Porsche Macan Turbo
    Thank you for the link, very much appreciated!! As usual "crapa"talk search has failed me once again!
